Ron Davis radiator vs. Dewitts
Supporting Vendor
1 Post
Does anyone have any information to suggest that the Ron Davis radiator would cool a motor better than the Dewitt's radiator?
Former Vendor
All I can say is the Ron Davis radiators have cooled the badest machines we can build. Hot days at the track, no problem. Traffic, AC on, no problems. I guess this didn't really answer your question.
Randy
Randy
Supporting Vendor
1 Post
Randy
Randy
"AlohaC5" Senior Member
I installed the DeWitts Radiator w/ 160 T-stat and noticed a significant reduction in water and oil temperatures. I'm very pleased with the quality and that it's a "direct fit" for stock. Plus the price is better and they support this forum!
Supporting Vendor
1 Post
I have a Dewitt's now, and I like it, but it's just not keeping the motor as cool as it used to now that I have twin turbos on the car. It seems there are a few guys running around with the Ron Davis and modified setups like mine that keep their coolant temps pegged to the thermostat, but I'm not sure if they are the exception or the rule.
St. Jude Donor '05-'06
I just pulled the trigger on one of those Davis radiators with the engine oil cooler built in... I sure hope it works because Man was it expensive, however if it does its job and protect my motor .. it will be worth it.
Former Vendor
I can answer that question! Neither is better...they're the same. You see, they both use two rows of one inch wide tubes, the same height fin, and furnace brazed cores without epoxy.
Ron Davis radiators tend to cater more to the hard core racers that run track and high speeds. They standardize on fin spacing of 18-20 fins per inch (fpi) when the industry standard is somewhere between 11-14 fpi. While 20 fpi works great at 100mph, it doesn't work real well at cruising speeds because of the density of the core.
The Ron Davis radiator cost a lot more than ours, they have fabricated tanks (box) and we use custom made press-formed tanks. We also offer a superior 7 plate engine oil cooler, built off-set, so it doesn't block the coolant flow. Ron Davis doesn't pay the light bill on the Forum either, we do.
So if you want to spend a little more money and exceed all federal speed laws, the RD radiator is the way to go!
Great info.. Wish I had that info earlier. I am going to check with my installer and see if my order can be canceled. It appears your product will be more in line with my use rather than a Davis radiator plus I always whenever possible make my purchases from a supporting vendor.-O'Neal
Your radiators are now available with an oil cooler? I missed that on your web site. What is the upcharge over the standard radiator?
I am in the market as well and would like the same information. Radiator + oil cooler.
I was sold on the RD unit. Let us know.
Thanks,
Sean
OT: O'Neal is your car at MTI now? I am having them install a CLB for me Saturday and KooKs 1 7/8 LT and 3 x 3 hi flow cat x pipe next Friday. Jeff also told me about the Ron Davis, I am reviewing all vendor options now such as the DeWitt radiator. Thanks Jason.
Former Vendor
This radiator/oil cooler has worked well with many cars that run over 170mph for long periods of time.
http://www.lgmotorsports.com/shop/pr...010401520b68d7
Howdy Folks!
I know everytime I've asked a question, Tom is quick to respond - it sounds like there's a good 4 or 5 folks interested in the radiator and/or integrated oil cooler.
Maybe a small price break if he get a few orders at once? ("mini GP )
Supporting Vendor
1 Post
Tom,
Does your oil cooler still have a 6AN size connection? Have you experienced any pressure drops from use of this cooler?
I've talked to a few turbo savvy shops that do a fair amount of oil cooler setups -- Xtreme Motorsports and Lingenfelter. Lingenfelter recently moved to an oil cooler setup that uses 10AN connections because they were experiencing some pressure drops with 8AN connections. I recently bought a 10AN adapter block from Xtreme Motorsports at the advice of one of the techs who also said that with 8AN connections/hose they were seeing some pressure drops at startup and while the car is running.
I am concerned that a 6AN size connection might not be enough. I think the Ron Davis radiator comes with a 12AN connection for its oil cooler?
Originally Posted by houston-z06
Hopefully we will get an answer back soon...I am ready to buy now, agree O'Neal re: supporting forum vendors ..
Originally Posted by ONealLaw
Hello Jason, Yes my car is at MTI now.. It is the Black '04 coupe with black out kit and Z06 motorsport wheels. I am getting a 383 stroker with F1R and etc. installed. --O'Neal
I will also be gettting a 383 stroker installed by MTI in the next 4 weeks, I plan on putting the new C5 KB on this fall as well....
if the KB is a no show, it's A&A D1SC all the way
I will check your car out Saturday, I only work 2.5 miles north of MTI.
I have the Ron Davis radiator/o.c. combo from DRM and it works very well. Last year I ran 2 events at VIR where the temps were 100+. During 30min sessions my oil temps never got above 240 and water never above 220. Quality is topnotch.
