Best Spark Plugs
Best Spark Plugs
I have a 99 Coupe with black wing intake, Magnaflow exhaust with Xpipe, getting ready to install new headers, thought I would change the plugs while I"m in there. Bought MSD plug wires, any suggestions as to which spark plugs to install?
NGK TR55's work fine for me. I have the same MSD wires also. IMO your not gonna get a HP increase from any plugs or wires so go with whats $ensible. You can find a good set up at www.corvettegarage.com. Make sure to get some heat sleaves to keep your wires from melting from your headers.
1 Post
St. Jude Donor '05-'06
Originally Posted by eamador11
NGK TR55s are officially the best spark plugs you can get for a C5.
Dave
How much better are the TR55 over the stock Delco iridiums? Also, how often do you need, or should, change the TR55's?
Inquiring minds would like to know.
Ed
Originally Posted by C5XTASY
Personally, I believe that if a sparkplug is of the proper physical size, of the proper heat range and has proper gapping there will be absolutely no measurable difference in performance Just MHO.. I have never seen actual, documented and verified, performance proof (acceleration, dyno, quartermile, etc) that one brand, or type, is better than another, other than the pucks falling off the original Delco platinums. All I've ever seen is opinion and I guess we're all entitled to one. I run the Delco Iridiums, have been more than satisfied and don't have to change them out every year. It works for me.
Ed
Ed
Ed
Ed
