Milling Heads -Double Post - Sorry
Former Vendor
Milled .030 equates to 5 cc reduction in chamber volume....that puts your chamber volume around 62 cc's. With an aftermarket .040 gasket you would have about 11.1 - 11.2 or so CR....with the thicker factory gasket I believe you would come in around 10.9 - 11.0 or so.
Call me at AFR if you really need exact and I will figure it for you quickly, but the figures above will be very close.
Tony M.
(818)890-0616 Ext 109
Tony M.
St. Jude Donor '05
