sylvania silver stars fog light bulbs
i have a 1997 vette that i have changed the head lamp bulbs and would like to know what the brighter fog bulb part# is for the silver star bulbs. i know 893st is what there web site shows but some people here have used a different number i think it is 885st. is this correct.
thanks for any help!!!!!
Mitch
speednut2@aol.com
Mitch
speednut2@aol.com
St. Jude Donor '05-'08
885s are the fog replacement, but I believe they are not considered SilverStars.
When you do it you should also adjust your fog lights up somewhat. They come in set low from the factory. It is a simple twist of a torq #15.
Mitch:
I have never found Silver Star fog bulbs. But the real point here is that I did purchase Silver Star head light bulbs and turn signal bulbs and the MARGINAL improved lighting does not offset the cost.
Ecklers sells whiter brighter fog bulbs. Or just upgrade to the PIAA 1100 series $189.00 for upgrade. Look at LAPD for details. It's expensive because you have to replace the entire housing.
Hope this helps.
Mike
Hope this helps.
Mike
Location: Redsox, Pats, Celts & Bruins !!! Redsox Nation !!!
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
Originally Posted by ben dover
The re-aiming is more affective than the bulb change.
http://www.c5forum.com/diy/fog_lamps.php
Silverstars are also a big waste of money, IMHO
Wattage is wattage, regardless who makes them
Originally Posted by MITCH
will the 885 fit right into the the fogs with no problems. is the wiring ok with the extra watt's.
thanks
mitch
thanks
mitch
you will not need to change anything. Just take out the old and out in the new. I have been running the 885s for over a year without an issue.
You will notice one big difference between stock and the 885s. The stock fogs have a cap over the top of them to displace the light to the left and right. The 885s do not have that cap so you get more light in front of you.
Originally Posted by tsts
Where is that #15 torx screw that adjust them?
Originally Posted by VetteSiNz
You'll see a square hole on each side of the Fog lamp. Use a flashlight to see the torq screw, I believe it's a #15.
you will have to use a real #15 torq not the interchangeable ones that you put on the end of a screw driver because the hole is too small.
I bought a #15 and I use it all over the car so it is worth the few bucks to have it....
Originally Posted by jnsfeeney
I disagree - I replaced my stock headlamps with Sylvania Silverstars and there was a noticeable difference - much whiter light that stock. Saw same impact on wife's 98 4runner. Not bad for about $35/vehicle.
For about 1/10th that price you can get the cheap "Xenon" type bulbs. They lasy just as long too. They are the same color and wattage. You will never know the difference. Paying $35 for bulbs is insane.
I'd be willing to be you have not lined up 2 cars - one w/silverstars and one w/the 'xenon' cheap bulbs - there is a visible difference. Those cheap xenon imitations look quite cheesy, except maybe on a honda civic w/neon, big fat wing, etc...
Any amount of money.
I had them in my wife's BMW 323i with the real Xenon lamps. The fog's on the car were yellow compared to the blue Xenons. I changed the fogs to the 6000k lamps and they looked like the 25 dollar "silverstars" night and day difference from stock.
The blub's color is what you are looking for. 4k 5k 6k and 6.5k
But hey's its your money, waste it if you like.
