ok to reuse oil pan gasket?
Originally Posted by TT_Vert
i pulled my pan. it didnt leak before an looks fine.
dave
dave
RJ / Gen 3 Motorsports LLC
dave
dave
Originally Posted by jimcork1
Ok,, I have learned the hard way... I always use a new gasket when the job is more than a 5 minute repair. Guess I got too old to do the job twice. Your choice,, if you can change it easily use it,, but if you have to jack,, pull ,, move,,, etc.. I would go new every time. Just my $.02. 99 Nassau Blue
lol get this. 36.80 for that plug at gm!! 55.94 for each 1/2 of the oil pan gasket and 01+ roid bolts are 8.27 each!!! Can anyone get me part #s on these, and ill just see how much GMparts direct and the other forum vendors are?
dave
dave
dave
dave
Have you located your noise yet?
nope, the 2 rods ive pulled so far look brand new. I gotta check mains, but i dont know how to check for wrist pin noise.
Dave
dave
dave
Gaskets
dave
dave
I wouldn't bother with the 12562020 lower pan gasket as it can be easily replaced if it happens to leak.
What's the plug you are talking about?
As runamuck noted in your previous post, the bolts/studs are not pressed into the rods like many other engines, so rod distortion is not a problem. Use the ARP bolts.
thanks i ordered arp pro bolts. not the expensive ones. Also, the plug is the oil level sending unit plug that plugs into the pan.
Dave
Dave
You your noise could be your Vette revolting against your forum name: TT_VERT. Maybe it thinks that stands for an Audi TT. or it could be Twin Turbo, in which case your Vette should have a big grin.
maybe its mad that TT is for my old TT mustang it it feels left out. Or maybe its the fact that it shares the garage w/ a cobra kit car and its jealous?? lol
The cobra was first, so the baby would have to go..
dave
dave
