Burst of steam
Old 07-20-2005, 11:20 PM
jmliles
jmliles's Avatar
Default Burst of steam
It was pretty hot today, around 100, and I had something happen that I've never seen before... so I'm looking for some ideas.
I'd been driving the vette around all day, no A/C, just windows down. It's probably been a couple days since I last used the A/C. Anyway, I end up sitting still in traffic on the way home for about 10 minutes and finally decide to turn the A/C on. So I press the button, 2 second pause, and a huge plume of steam (with the smell of coolant) comes forward from the back underside of the vette. Very puzzled, I cut it off and drive home.
No leaks, coolant is fine, temp was about 225 when it happened. Hasn't ever done it before and didn't do it again when I tried a couple of times later today.
Any have an idea as to what happened?
Old 07-21-2005, 09:08 AM
Silver98
Silver98's Avatar
Not to insult you at all, but since there are no coolant lines in the rear of the car, could it have been the car behind you?
Old 07-21-2005, 12:28 PM
Flintstone
Flintstone's Avatar
I'm pretty sure he was implying it came out of his exhaust!!
Old 07-21-2005, 01:45 PM
jmliles
jmliles's Avatar
I should have clarified that there wasn't a car behind me at the time, since that's a pretty obvious initial question. It was definitely me.
The fact that there are no coolant lines even remotely close to the back is why I was so puzzled in the first place. I'm not worried about it, just really curious about what might have done it.
Old 07-21-2005, 01:48 PM
Silver98
Silver98's Avatar
I'm really sorry. I didn't mean to insult. Please no offense intended
Old 07-21-2005, 07:43 PM
jmliles
jmliles's Avatar
Heh, none taken, that was a perfectly fine question.
Old 07-21-2005, 11:46 PM
Threed
Threed's Avatar
Location: GOCC - Rebels Without A Clue Santa Barbara, CA
But is the AC working now?
Old 07-22-2005, 02:39 PM
Evil-Twin
Evil-Twin's Avatar
Received 3,812 Likes on 1,925 Posts
St. Jude Donor '03-'04
Steam out of the exhaust????? Smell of coolant.
Possible head gasket, or a cracked water jacket dumping "Coolant" into one combustion chamber.
Old 07-23-2005, 01:43 AM
mwagne16
mwagne16's Avatar
Might be time for a leak down test, or at least pull the plugs for an inspection.
Old 07-23-2005, 02:01 PM
Vector
Support Corvetteforum!
Vector's Avatar
I thought head gasket. I'd check the oil for coolent as well! Any engine work done lately?
Aren't you sorry you asked!
Old 07-23-2005, 04:52 PM
jmliles
jmliles's Avatar
A/C has worked flawlessly for the last 3 days or so since it happened and it hasn't happened again. Still haven't found any leaks or signs of anything wrong.
No engine work done, ever.
Because of the wind, I can't be sure it came out of the exhaust. If we ignore that part, is there any way turning on the A/C could have simply caused a dump of condensation onto any of the hot metal below the vette?
To Burst of steam
Quick Reply: Burst of steam
