Are PCM'S interchangeable?/?
Can you use different year pcm's in your c5? Example, can I put an 04 z06 pcm in my 98 vert and use an hptuner cable for the 04 and have everything work?
Just wondering, Jer
Just wondering, Jer
To a point..... The biggest problem area is the connector of the wiring harness. I am pretty sure 1997-2003 PCM and wiring harnesses are the same and 2004 are different. John at Speartech can tell you for sure.
http://www.speartech.com/
Keith
Keith
