Is the Z06 Clutch PP adjustable like the LUK?
1 Post
St. Jude Donor '08
I'm just wondering if the factory GM Z06 PP is adjustable like the LUK gold clutch PP. From what I remember I think it is but I'm not 100% sure. This also leads me to ask is the Z06 clutch and LUK the same? I would run out and buy the LUK but I don't want an aluminum flywheel as I drag the car. Thanks!
Yes it is. It can be done on the car. I can send you the procedure if you email me.
edbon@adelphia.net
edbon@adelphia.net
edbon@adelphia.net
edbon@adelphia.net
Thanks for all the help you have given me and many other members.
1 Post
St. Jude Donor '08
Patches-thanks! Just to clarify the Z06 clutch is the Luk ProGold? I have the adjustment procedure-I wish I new about it after I had the Luk and it started to slip. I switched to Exedy but a I am not happy with it. I will probably go back to the Z06 clutch-I got over 150passes out of it on ET STREETS before it began to stick-for the money best clutch hands down.
