Clutch Rattle Question
St. Jude Donor '05-'08
So I had my clutch replaced recently and I cannot remember if the old clutch rattled when the car was idling in nuetral.
I know the car makes a weird noise when it shuts down and the clutch is out with the car in neutral, but I am not sure if I remember the car making a noise when just sitting in neutral.
I know it is the clutch because when I press the clutch pedal in the noise stops. In gear, of course, I can tell what is going on because the clutch is either in or out, but definately there is a noise in neutral with the clutch out.
Just wondering...
thanks
Just wondering...
thanks
Mine rattles and always has, so I think yours is fine. Sounds almost like a thin metal rattling/vibrating?
I've got a question for you - did you replace it with a stock plate, if not what type? I got stuck on the freeway for an hour tonight in stop 'n go and took the last life out of my clutch and or something went south on the hydralics - pedal went down to near the floor and just barely made it home into the garage before it was completely shot. It seemed to go pretty fast so I'm think a seal may have gone on the hydralics. Any thoughts?
Thanks,
John
Thanks,
John
Thanks,
John
Thanks,
John
Chris the owner of ECS is using the same clutch in his road racing car and stated that he ran all day at Watkins Glenn and the clutch felt as smooth at the end of the day as it did at the beginning. I believe he has 3.90 gears and over 450 RWHP on that car.
thanks for the info - I'm going to check things out tomorrow and if it's still bad, I'll be in the market for a new clutch. I live in Arizona near Xtreme Corvettes - they put on my Corsa Indy's - so I'll probably go see them.
thanks again,
John
thanks again,
John
Premium Supporting Vendor
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In V Veteran
Originally Posted by phils C5 vette
Im needing a clutch. does the RPS chatter ?
do you have to rev it hard to start rolling in first gear, or is it like stock ?
Cruise-In V Veteran
chris,
how is it on the street
you rcommended LUK
then Aussie
and now RPS
Your killing me !!!!
you rcommended LUK
then Aussie
and now RPS
Its kinda funny how every 6 months there is a new "clutch of choice" The Luk is nice for a bone stock engine or a very mild one. They drive nice and all but I would go a little beefier. The Exedys were last years clutch of choice untill we came upon a bunch of issues. I really like the aussie clutch. Its a bit on the heavy side but it works pretty well. After I tried a few RPS clutches in customers cars I had to have one. Awesome pedal and very, very smooth. I have about 750 miles on mine and am very happy with it so far.. Maybe next week it will be a Spec stage 3 or something
Phil I sent you another PM.
FYI
As I mentioned the RPS clutch is great. I ran it all day Saturday at ETown with no issues (though this is my last 1/4 run - I hate beating on the car like that - and Chris talked me into Road Racing anyway).
Rattle? Well there is some noise when the car is idling. The noise is not much, but from what I have read and heard some others clutches make a lot more noise. I did not hear the noise until I was working on the car inside my garage where it could echo off the cement floor.
Again I will give you better feedback after the H/C package that ECS is putting in soon, but since Chris already has it in his car with almost the same setup I see no problems (of course that could be the reason he is looking to sell it )
FYI
[QUOTE=Wicked Weasel]
FYI
WW, Sorry to hear that your not going to drag race anymore, but
do you really think road racing is not beating on the car??
I would think road racing / auto crossing is more were and tear on the car than drag racing, just my thoughts
FYI
My thoughts about wear and tear on the car is something like this:
1/4 mile is like getting up at 5am and jumping out of bed and going for a full sprint.
Road racing is more like getting up, putting your shoes on, and then going for a jog which turns into a run. This just seems to be a bit less harsh on the car.
Regarding parts - well I would say that typical 1/4 mile cars go through tires, transmissions and clutches while typical road racing goes through tires, brakes, and rotors. I would rather pay for brake pads and rotors then clutches and transmissions (though I still have to do more research on what parts break most often on road racing cars).
I do agree that any racing (even street racing) is hard on your car and if you can't afford to break things then you should not be doing it.
Another influence is that I want more than 12 seconds (soon to be 11 seconds ) of excitment. Road race sessions can be 20 mins. turning, braking and accelerating.
Finally I don't think that I would be ever good a bracket racing. Not that I am bad at RTs (many in the sub .05 range), but having a 6 speed I can not be consistant with 1/4 mile times. If I miss 1 shift point I am missing my ET which when it comes down to the Big Boys you can't afford. In a road race I can make up time through being a better driver by braking later or exiting turns better.
I guess they are just different forms of racing. Who knows I might really stink at road racing and then I will have to move to Water sports like that ZR1 this weekend
Clutch Rattle 2004 C5
2004 C5 6 speed.
Recently purchased very low milage C5 with 6K miles. I have clutch rattle in neutral that seems to be clutch related because it goes away or changes pitch with activation of clutch. Also sounds like a metal cage rattle when accelerate in first gear or when lugging in higher gears.
Dealer says " normal and usual" condition. Showed me a tech sheet.
I am still skeptical
Any thoughts
Any thoughts
Originally Posted by tomg38
2004 C5 6 speed.
Any thoughts
Any thoughts
Have you tried shutting the car off in neutral without the clutch in that noise is really loud...
Cruise-In VII Veteran
Just wondering...
thanks
Just wondering...
thanks
St. Jude Donor '12-'13-'14
You know I love to hate you ! you know what I want to know about cars.
You made your passion your living. I make a living on killing people with a passion . Lets trade ! My car never answers me back
The noise you hear when the clutch is out is the spinning of the driveshaft and the gear rattle of the transmission. The main shaft of the trans is spinning and causing the gears to bumb into each other. This is a normal noise which we all hate but is normal. When you push the clutch pedal in everthing stops rotating and the noise stops. Jimmy
