2001 LS6 Head
Old 08-01-2005, 07:26 PM
slowjunk
slowjunk's Avatar
Default 2001 LS6 Head
How do you tell a 2001 Ls6 head from a 2002-2004 Ls6 Head. They are both 241 casting numbers right?
Old 08-01-2005, 07:38 PM
SFVetteman
SFVetteman's Avatar
The heads are the same but the valves and valve springs are different. the '01 uses LS1 valves whereas the newer heads use slightly longer and lighter titanium valves. The springs are identified by the color. I believe the '01 springs are yellow and the newer ones blue but I could have that wrong.
Old 08-01-2005, 08:51 PM
Kexec
Kexec's Avatar
Default Heads
Also the Z06 casting is 243 not 241(LS1 head)
Old 08-01-2005, 09:20 PM
Tino
Tino's Avatar
I believe the valves in the 02-04 are light weight sodium filled. These are not titanium valves, the new Z06's will have titanium
Old 08-02-2005, 07:50 PM
slowjunk
slowjunk's Avatar
Default 2001 to 2002 head visual difference
Visually other than the spring color, which I've heard is really not consistent in color or application, how do you tell them apart. Are there casting bumps, printed on parts numbers, etc. I'm looking at buying a pair and don't want to end up getting 2001 heads.
Old 08-03-2005, 02:13 AM
jjjflex
jjjflex's Avatar
Old 08-03-2005, 04:52 AM
vettenuts
vettenuts's Avatar
The original springs have a paint dot color code on them, unfortunately I don't remember the colors well enough to advise you. Do a search over on LS1Tech.com as well, this information is likely found there. This is of course assuming that the original springs are still on the head. Not sure what the visual differences are in the valves, but a quick e-mail to Bob at Precision Porting will likely provide some information on the valves as well. Good luck
Old 08-03-2005, 07:47 AM
see5
see5's Avatar
The LS6 heads are #243 and I believe the 01 springs are blue with non sodium valves while 02-04 valves are sodium and springs are yellow. 05 LS2 is a 243 head with non sodium valves.
To 2001 LS6 Head
Quick Reply: 2001 LS6 Head
