pcv amw catch can?
Former Vendor
St. Jude Donor '06 & '12
Originally Posted by stickystuff
i have an 03 zo6. im hooking up a amw catch can. do i need to leave the pcv hooked up or can i run the new lines without it?
You have to use it. Leave it in line when you hook it up.
Originally Posted by AFBombdude
The screwdriver points to the new location of the PCV valve.
Originally Posted by FFR-Z06
But thats not a Z06, the Z06 with the LS-6 engine has the line coming from the valley cover and if I'm not mistaken the PCV valve is internal to the valley cover so he won't have a valve like yours.
Originally Posted by H20Vette
That's right, that's not a Z06 motor, at least not a late model one. I have an '04 LS1 coupe and there is NO external PCV valve (it's just like the LS6 setup). Here's some pics of my install:
Former Vendor
does any one have a shot of a 2001-2003 zo6 with a catch can hooked up?
CI 7 & 9 Veteran
I have a few questions
I've got a few questions.
Are those cans in the pics above being held in place by the hoses, or is there a bracket I don't see in the pics?
Do the hoses come with the cans or would I need to get them seperately?
Is there a write up anywhere on the install procedures, or do the cans come with good instructions (visual pics help)?
Where is the best place to get a catch can?
Thanks in advance for your answer.
I put mine on the Battery partition. I don't have room on the front of the head because of my blower. I cut the AMW bracket off and used just the top portion to run the mounting screws into on the back side:
It works too. Time to start thinking about forged pistons...
my 2003 z06 has an external pcv. i ran the top line with the pcv to to top of the catch can. the bottom line off the engine is running to the bottom of the catch can. this is what the amw instructions showed. i have not seen pictures like this. is this correct?
Bottom of can to intake
