drain coolant ????
drain coolant ????
Want to drain my coolant tomorrow. Question how much coolant will drain if I just open the radiator drain **** ? Also any tips to get maximum amout out dont want to fool with block drains.
TIA Jerry
TIA Jerry
Originally Posted by white top
ttt
how much coolant drains when opening the radiator drain ****?
12.6 quarts capacity for the whole coolant system. I ususally get between 5 and 6 quarts out of the radiator. Another couple quarts by siphoning the overflow tank.
Cruise-In VII Veteran
ahhhhh, now i realize, the reason all the coolant drained in my car was because the t-stat was broken allowing all the coolant to drain out of the block, if the t-stat is closed it won't drain, you can remove the 2 bolts that hold the tstat to the w/p and drain the rest, it will make a mess, i'll have to post pics of tstat later when i get my camara back
I drained what I could out of my radiator and then started the car and let it idle until it was over 230 degrees. I think the T-stat opened because more coolant came slowly leaking out at that point.
