6 Speed transmission Rebuild - CorvetteForum - Chevrolet Corvette Forum Discussion
Register FAQ Search Today's Posts Mark Forums Read Vendor Directory
C5 Tech
Corvette Tech/Performance: LS1 Corvette Technical Info, Internal Engine, External Engine, Tech Topics, Basic Tech, Maintenance, How to Remove & Replace
Old 10-17-2005, 02:51 AM   #1
clone477
Junior Member
Default 6 Speed transmission Rebuild
Hey guys this is a repost, I wasnt getting very many replies under the general section, try my luck here.
Just recently I noticed that my 2001 Z06 has been grinding when going into 4th gear only when cold, so it looks like a rebuild will be in the near future. My question is who has torn into one of these 6 speeds to replace all the syncros?? Anyone know of an online disassembly guide?? Or did anyone find a 6 speed service mannual on ebay?? Ive done my share of 4l60e and am a licenced auto tech, so Im not to worried about ripping into it, but wanted to know other peoples experiance. Thanks Guys
clone477 is offline   Reply With Quote
Old 10-17-2005, 06:18 AM   #2
John Shiels
CF Senior Member
John Shiels's Avatar
Location: Buy USA products! Check the label! Employ Americans
probably in service manual
John Shiels is offline   Reply With Quote
Old 10-17-2005, 02:46 PM   #3
MrPDJ
CF Member
MrPDJ's Avatar
Try this thread over at LS2.com forums.
It's the best post w/pictures I've found for rebuilding the t-56. I ended up having mine rebuilt at MTI here in Houston.
Good luck with the re-build.
MrPDJ is offline   Reply With Quote
Old 10-17-2005, 03:10 PM   #4
ericdwong
CF Senior Member
ericdwong's Avatar
Good link. Here is the service manual: http://www.ttcautomotive.com/English...ice_Manual.pdf
This service manual also covers the F bodys, Cobras and Vipers so some of the parts are a little different then the C5 (namely the "extension housing".. you'll see what I mean if you get that far).
I have replaced my 3rd gear synchro assembly (3rd and 4th gear synchros were one assembly if I remember right). It wasnt particularly hard, just time consuming. I got the replacements from Rockland Standard Gear (rsgear.com).
Your symptoms are exactly the same as mine- when cold it would grind. Bleeding the clutch and changing the trans fluid did not help. It progressively got worse.
Fortunately/unfortunately my slave cylinder died, so while the trans was out, I rebuilt it, on jackstands none-theless. If you need help, ask or PM/email me.
While you're at it, change the clutch/flywheel/hydraulics and add a DTE brace.
ericdwong is offline   Reply With Quote
Old 10-17-2005, 06:55 PM   #5
CrazyChris
CF Senior Member
Thanks for the links!
CrazyChris is offline   Reply With Quote
Old 10-17-2005, 09:19 PM   #6
clone477
Junior Member
Yeah thanks very much guys thats what I was looking for. Now is there a company that offers a complete rebuild kit??
Old 10-18-2005, 01:17 AM   #7
Operations
CF Senior Member
Support Corvetteforum!
Operations's Avatar
Operations is offline   Reply With Quote
Old 10-18-2005, 08:43 AM   #8
clone477
Junior Member
Whats the popcorn for?? Was I not supposed to ask were to find a complete rebuild kit??
Old 10-18-2005, 10:40 AM   #9
ericdwong
CF Senior Member
ericdwong's Avatar
Not sure if theres a total rebuild "kit", but I got my rebuild components from Rockland Standard Gear www.rsgear.com . I only used standard parts, not performance parts. I dont plan on making my car run 10s. But so far so good, almost been 1 year, no leaks, grinds, funny feel etc on my daily driven car, almost 15K miles thats seen snow, towing a trailer and the drag strip.
Old 10-18-2005, 11:09 AM   #10
Operations
CF Senior Member
Operations's Avatar
Quote:
I want hear the answers you get because I want to know also. Possibly others have a diffrent idea as to the meaning of the popcorn pick, I see it as a method to watch a post I am intrested in. So I'm hanging around waiting to see what happens?
Old 10-18-2005, 08:22 PM   #11
Fastguy
CF Senior Member
St. Jude Donor '03-'05
Fastguy's Avatar
Quote:
Usually the popcorn means "this is gonna get good, I'm going to have some popcorn as this guy gets ripped on".
I may tear mine out this winter for a rebuild. Usually the only specialty tools you need for a tranny are good snap ring pliers, a dial indicator and a press. Hopefully thats all I need for this one.
Fastguy is offline   Reply With Quote
Old 10-19-2005, 08:39 PM   #12
DRR
CF Senior Member
DRR's Avatar
I found the T-56 manual at Tremic.com, complete with exploded views.
DRR is offline   Reply With Quote
Go Back   CorvetteForum - Chevrolet Corvette Forum Discussion >
Reload this Page
  • 6 Speed transmission Rebuild
    Related Topics
    Thread Thread Starter Forum Replies Last Post
    Website showing how to rebuild muncie 4-speed? cratica C3 General 4 12-11-2009 12:34 AM
    Doug Nash 4+3 Rebuild? Enzo_Guy C4 Tech/Performance 5 03-13-2008 03:30 PM
    Muncie Rebuild jhuff C3 General 12 03-14-2007 11:39 PM
    C4 rebuild - Speed channel now Central time tjfontaine C4 General Discussion 45 09-24-2006 10:40 PM
    SPEED O MOTIVE Mr.Gearhead C3 Tech/Performance 9 04-20-2002 12:12 AM
    Tags
    c4, c5, corvett, corvette, exploded, gear, manual, rebuild, rebuilt, service, spd, speed, t56, trans, transmission, view
    Search this Thread:
    Click for Advanced Search
    Posting Rules
    You may not post new threads
    You may not post replies
    You may not post attachments
    You may not edit your posts
    BB code is On
    Smilies are On
    [IMG] code is On
    HTML code is Off
    Trackbacks are Off
    Pingbacks are Off
    Refbacks are Off
    Forum Jump
