telescopic steering wheel not working
My telescopic steering wheel will not move when I push the switch forward or backward. Has anyone had the same problem. There's no sound when I try the switch.
I've got the same problem. I diagnosed it as the actuator under the dash needs replacing. The actuator is the "motor" assembly that runs the steering column in and out.
To replace the actuator, you have to remove the plastic panel that is directly above the brake and gas pedals, remove the center counsel and then remove the drivers side knee bolster. I'm going to do it this winter since although I don't think it is a horribly time consuming or tough project, winter sounds like a better time to do it.
By the way, if it turns out that it is your actuator that needs replacing, let me know, since I have two of them, and I only need one. (don't ask why I have two of them). They are about $360.00 from the stealership, and I'll make you HECK of a deal.
Before you replace the switch move the acuator 5 times in the same direction. Out or in does not matter. This resets the computer and may fix your problem. Had the same problem with mine and it works ok know. I understand that sometimes it goes beyond a stop and sticks.
If it travels beyond the stops , how can this be resolved. Mine clicks when I push the switch in, nothing pushing switch out. Sometimes the wheel is in the out position when I enter the car. Pushing the switch in moves the column pull out does nothing. Mine is a 99
i have the same problem in my 02, my driver seat works abut my telescopic **** has no clicks in it it is just free and moves with no resistance.. any thought about that?
Look at this link. In particular, my Post #7.
https://www.corvetteforum.com/forums...post1589934140
If that does not fix it we can look at further diagnostics.
Mr. Sam
Mr. Sam
mind of it's own
Mr. Sam
Mr. Sam
how would you do that? I took out my seat to put in racing seats and set the wheel out before I took off the seat harness. It has stayed, but I feel it has sunk in a little.
Booger789 (08-17-2018)
Easy, the harness for the seat which you disconnected feeds the TSW. You just put power on the correct pin/color wire and if the TSW works you can move it wherever you want. The TSW ground is in the dash area so all you need is 12 volts.
Mr. Sam
Mr. Sam
