How to remove C5 Dash Board?
Cruise-In VII Veteran
Originally Posted by DJMRTS
Does anybody have instructions on how to remove and replace the dash board? Thanks
ck out the hud install, it covers the dash pad
Originally Posted by connecticut
if you need the whole dash out then get a gm shop manual or borrow one from a local member; what's going on w/ the dash?
Use the link posted above.
I had to take my dash apart to get the pass side airbag cover properly aligned.
Once the dash pad is out, the rest of the dash is easily accessible
I don't think the entire dash has to come out just the support bar at the bottom of the dash, the one that goes across to the passenger side.
I have been told that its easier to swap the pedals out with the dash removed. I'm converting to a MN6 from an A4.
Do not remove ur dash.. There is a 15 nut that is accessible once you pull back the insulation above the pedal assembly..The insulation has a slit cut in it to make it easier. Place a long socket in there with a medium extention and use a 13mm wrench to turn the bolt head that is visible..It is not hard. Just look up thre and you will see what i am talking about..The black plastic piece with a slit is above the pedals..
Originally Posted by JSTAN
How has the swap been? I am planning on doing the same. Any tips?
Andy at A&A ( a well respected vette shop) said that he will never do a tranny conversion swap again.
i just watched mine come off due to a replacement of the flasher! took 1.5 hrs each way. the instructions are in the service manual. watch the wires in the dash vent
are you gonna be doing this job by ur self? It is alot of work but not that hard..Hope all goes according to plan..
As you can see, I'm not in a hurry to do this swap. I am going to attempt to do it a weekend at a time, a step at a time. What dash board wiring harness differences are there between the A4 and MN6?
What swap tips can you offer? Thanks
Tony ,get urself the wiring schematics for the car. This will make things easier..You will need to address the Anti theft circuit, Starter enable circuit and Add the clutch switch..This is not hard at all. If you get the schematic for the A4 and M6 you will see where the wire start and end..You will need to add a few pins into the PCM if you don't change the harness and that is not a big deal....If you chose to change the wiring harness you will ned to change it with a car with the same features..Ride control, suspension etc..You can pic up wiring harnesses for cheap..97-98 only work together and 99-2004 for the rest..Get the service maunual and you will not have any problems..I did the conversion the other way and can't see it being very hard the other..The guy i bought my stuff from was up and running in one day..
