Coolant bubbling?
Bubbles in coolant
A sniff test is done to see if there are any comtaminants from the combustion chamber in the coolant-a sign of a blown head gasket or cracked head or block.
could it be air stuck in my system? can i open up the resovoir and start the car, run it till warm and then just close the cap?
anyone done this with the ls1?
no residue at all i even took some out and dried it to see if there were any solids in my fluid and none at all....
im about to run my car with the cap off until it warms up and then replace the cap, maybe that will help...
Most garages can do a sniff test in about two minutes. I have never seen mine bubble, but I also have to admit I never looked. Bubbles are usually a sign of a head gasket issue though.
look at oil really close for milky color (the absence of milky color will prove nothing, but if you have it, odds are that you have a blown gasket) you can also pull plugs and look for water on plug.
good luck
More Than Zero
good luck
More Than Zero
