ANY drawbacks AT ALL using AMW catch can?
I just installed it, but a few yrs back, when I had the Campbell Hausfeld jar separator, I had a performance drop off & removed it..
The AMW seems the way to go with higher compression & HP cars now..
Anyone have any issues since they installed it?
Originally Posted by ArKay99
Could you explain the performance drop-off? I'm curious.
I run a big Ebay AMW style now and highly reccomend it.
The culprit was found to be the air stone type filter in the jar..
Most guys removed it & got much more oil in the jar, others drilled a hole in it...
However, the AMW catch can seems to be the way to go..
But, I haven't heard any negatives on it, so I wanted to make a post just to see if anyone had anything to say on it, and so far, the AMW is getting all thumbs up..
Alot of us felt performance was sluggish with the CH air separator jar..
"AlohaC5" Senior Member
Same setup: AMW Catch Can and Chrome Oil Breather Filter Cap. Works great! No problem at all during road racing events. The AMW system collects a significant amount of oil, which would otherwise go into the intake manifold.
Originally Posted by peter pan
I have an AMW Catch Can on mine and it has worked without any issues. I also removed the oil filler cap and installed a chrome breather to assist and this has also helped
I have the CH and just broke off the stone filter...you don't need it anyway. Your not filtering anything, just catching excess oil. I can't see how this is any different than the AMW except for capacity
Hey guys, how about a little more info on the Chrome Oil Breather Cap, is it a direct 1/2 screw on cap like the stock cap or do you need some type of adapter? and where did you get it?
I have been running an AMW catch can for over a year but a breather would be a great addition.
I installed my breather a few days ago. However, while it did screw in where the stock oil cap was located, it would have crushed the breather when I closed the hood (I checked the clearance before closing the hood). So, what I did was to cut a circle in the insulator (I think that’s what it’s called) which shaved off enough space for the hood to close with no problems.
Originally Posted by AlohaC5
Here is a link on the PFYC site to their Chrome Oil Breather Cap: http://www.pfyc.com/store/merchant.m...y_Code=VTUNDER
And wouldn't it affect fuel trims & require new tuning?
Is an oil catch can really necessary for the average street driver??
I've seen some posts that say it's great for those who run alot of WOT, but as I use my Vette for commuting, highway driving, but no track, do I really need an oil catch can?
Chris
I got one because I wanted to keep my tune accurate without cooked oil bumping my compression and causing knock at the track.
Oh, and for those who think the stone in not needed, it sure is for best results. I also ran a small bead of RV sealant inside the bowl about 1/4 of the way from the top to prevent the oil frokm creeping back up the bowl. Not sure if it did creep up the bowl, but I figured it might help.
And, for those that think the bowl is too small, you can just buy the larger CH filter for $30 or so.
For me, the little $14 CH filter is perfect. It's small, and works extremely well. I mounted mine in the battery compartment. Because I have that bead of RV sealant inside the bowl, I removed the valve on the bottom of the CH filter, and installed a small ball check valve from the plumbing department at Home Depot which enables me to drain the oil out the bottom of the filter, instead of having to pour oil out the top past the RV sealant bead.
I also like the fact that because the CH filter bowl is clear, I can easily see how much oil is being collected without having to remove the unit, as I had to do with the AMW.
Is anyone using the one LPE sells? From the pictures it looks like there is a fine mesh screen basket that fits inside the can. It seems to me, that the screen would do a better job of collecting the oil droplets, as the air passed through it.
Mine is a daily driver (with a little WOT every now and then) and I have about 3/8 to 1/2" of oil in the AMW at every oil change.....so yes, I'd say its necessary....or at least it gives me some comfort knowing this oil isn't building up in the cylinders.
