Brake caliper lube
Brake caliper lube
Just wondering if there is a special lube that goes onto the bolt that goes through the caliper, when I remove it it was lubed up, can a multipurpose grease be used such as a universal wheel bearing type grease, or should I use a synthetic grease.
The grease I have now is the valvoline red multi purpose grease, will this be sufficient.
thnx
thnx
I think i would still get the caliper grease. It is a high temp grease to withstand the high temp your brakes will create and it is used on the back of pads and shims to keep brake noise down (squeaking).
http://cgi.ebay.com/ebaymotors/ws/eB..._BIN_Stores_IT
Look at this ad, scroll down to where it shows the Pad packages, it shows a packet of grease, I do believe this is for the pads, the grease I am refering to is on the caliper pin bolts, the bolts that go through the caliper Frame and the caliper itself, when I took the bolts out to remove the calipers, it looks like a dark colored grease.
Originally Posted by Pizzano
[url]http://... the bolts that go through the caliper Frame and the caliper itself, when I took the bolts out to remove the calipers, it looks like a dark colored grease.
GUSTO
Received 2,180 Likes
CI 6,7,8,9,11 Vet
St. Jude Donor '08
The correct grease is the synthetic brake caliper grease that is specifically made for this purpose!!
Regular grease will boil out under hard braking and cause the caliper pins to hang up on the calipers. In some of the older brake calipers, using the wrong grease would cause the O rings to swell and cause the breaks to over heat destroying the pads and rotors!!
Also make sure that the pin boots are in good condition!
Bill C
Bill C
Cruise-In VII Veteran
thnx
thnx
