C5 Head Torque Specs/Sequence sheets?
I am putting Z06 heads on my C5 this coming weekend and I don't know what the torque specs are. Does anyone have a copy of the service manual page that shows torque and sequence of torque? Thanks.
pdf files are a bitch to copy! The J 36660-A tool mentioned is a Torque Angle Meter. JFYI, DO NOT reuse the old head bolts. they are TTY - torque to yield - once they yield (stretched), they are permanently deformed. BTW, the spec page is from a 2000 service manual.
Thanks. I already got new bolts and gaskets but thanks for the warning. Where can I get one of thoes tools to measure torque angle? The page with the sequence is mainly what I needed so thanks a lot for that. I'm certain that the 2000 and 02 are the same but I'll double check with the dealer before the job.
Ouch!
You don't even want to know what that tool costs! List price from Kent Moore is $846! I should have probably just linked you here to start off. Should be everything you need to know. Good luck!
http://www.ls1howto.com/index.php?article=1
