how hard is it to change the rear side marker lights?
Originally Posted by vetteguy8
i how do i take them off?
Originally Posted by LoneStarFRC
Remove your L/R tail light housing and reach inside. There are two nuts to remove that are 10mm I think. They are the stamped metal "PAL" type nuts.
except it's not 10mm... it's either 3/8 or 7/16 (I forget which). I would also strongly suggest using an offset box wrench
...and gripping it as close to the fastener as possible (so you don't break the plastic stud from leverage while removing the metal palnut).
the nuts are 7 mm, i change mine between red and amber now and then and i go in from the bottom without removing anything, but i dont have stock mufflers (Stingers) so there is some room.
the nuts are 7 mm
I also recently replaced my center brake light, and that does require a 7mm socket.
I changed mine to the Euro Amber (yellow) also; However, I just took off the outer rear tail lights to get to the side markers. After disconnected the old lense, pre-screw the nut to the new marker before the final install on the car.
On C5 convertible to replace rear side marker bulb on quarter panel, first remove two torx screws to remove tail lens to the extreme right. Next remove the two 10mm nuts securing the power antennae. Now you have access to reach side marker, twist bulb socket from light unit, pull out old #194 bulb and press in new bulb. Reassemble.
