This AMW catch can is WORKING!
Opened up the drain chock today after about 2 months of highway & spirited driving...
My car is a 2000, does NOT burn oil, and I did the AMW catch can because 3 yrs ago I felt the Campbell Hausfeld can killed my throttle response & bogged my car.. Once I took it off, all was well..
Installed the AMW, with no SOTP difference, & check out these pics!
I used a detergent lid to fit under the can to catch the oil, then poured it in a 2 oz bottle to see the actual amount.
Thats a full 1/2 oz of oil thats NOT in my intake! (see last pic!)
I'd say the AMW can WORKS!
Originally Posted by pdd000
the oil also goes through the passenger side vent line into the TB. i put a filter on that line too
I was told by a fellow member who has a custom catch can and I trust as very knowledgable that ....... no matter what AMW says .... the line to the intake manifold should be the top not the side !!!!!
DH
Since we are on this topic again, I made some modifications to my AMW. First off, I have a compressor catch can without the filter 1st in the line and it catches alot of oil. I relocated the AMW to the same place Howie has his, between the fan shroud and chassis where the hood hindge is attached. It stays much cooler there than it does being attached to the head. Secondly, I removed the spring clip and screen along with the steel wadding. I took a coke can and cut the bottom & top off and cut up the side, so the alluminum could be laid out flat. I rolled up the alluminum so I could fit it inside of the area where the steel wadding was. Now the oil has to go all the way to the bottom of the can, instead of about half way down, before suction can try to pull it back out through the side hole. I left a space of about 3/4 of in inch from the bottom. I did put some of the steel wadding back in to help form dropplets. Anyway the result is great! I have that glass fuel filter, with some breather element in it, in the line before the intake, and it is staying pretty damn clean. My car is a daily driver, about 300 miles a week. I was getting a ton more oil at that filter when the can was at the head and had not beed modified.
Sorry for rambling on
Glad to hear this thing is actually working. I just installed mine this weekend....but have yet to drive the car hard for any length of time. But i will be soon.
Originally Posted by allmee
I had a filter on this line also, but I was getting no oil to it at all. It took about 6 months to turn a very light brown in color. Oh well.
I was thinking of filling the entire can with that heavy metal mesh. Then reversing the lines .... that oil goes in side, has to swirl around LOTS of mesh to condense on, then has to be pulled all the way thru the top........
DH
Originally Posted by Dirty Howie
Same here
DH
DH
Originally Posted by vettenuts
Interesting, I thought about this as well. The only conclusion I could come to is they were trying to keep the level above the oil level in the container as the container filled.
DH
