car is saying to service active handling but code is steering c1287 any help?
What does this steering sensor c1287 mean should I have it checked right away or could it be a lose connection. Does anyone know were this sensor is located? Thanks
This code indicates the steering wheel sensor is reporting that the steer rate (how fast the wheel is turning) exceeds the EBCM limits.
The first possibility is an intermittent connection on the sensor resulting in the erroneous rate. These sensors use magnetic pickups and are not as likely to fail.
The service manual says to check connector C102 on the RH side of the engine block near the firewall. Reseat the connector and see if that changes anything.
The sensor itself is located at the base of the steering column on the left side just above the brake pedal. It looks like a ring around the steering column with the connector at the 9 o'clock position. Try reseating this connector as well.
The only other connector is at the EBCM module in front of the engine on the lower left side.
I really believe you have a wiring/connector issue. Check these connection points out and see if that addresses the issue.
I found the sensor above the brake petal and cleaned it with electrical cleaner put on and car would be good for a lot longer than before without the service active handling coming on but it does eventually come on. I can't find the other sensor on right hand side of block. Do I have to get to it from underneath or can I see it from the top. It's not actually on the block right?
Received 8,919 Likes
You need to get a service manual and study how to diagnose these types of problems. By the way did you have any work done on the steering recently. Or maybe some work done close to the lower end of the steering column. This will get you started:
DTC C1287 or C1288
Circuit Description
The vehicle stability enhancement system (VSES) is activated by the electronic brake control mdoule (EBCM) calculating the desired yaw rate and comparing it to the actual yaw rate input. The desired yaw rate is calculated from measured steering wheel position, vehicle speed, and lateral acceleration. The difference between the desired yaw rate and actual yaw rate is the yaw rate error, which is a measurement of oversteer or understeer. If the yaw rate error becomes too large, the EBCM will attempt to correct the vehicle's yaw motion by applying differential braking to the left or right front wheel.
The amount of differential braking applied to the left or right front wheel is based on both the yaw rate error and side slip rate error. The side slip rate error is a function of the lateral acceleration minus the product of the yaw rate and vehicle speed. The yaw rate error and side slip rate error are combined to produce the total delta velocity error. When the delta velocity error becomes too large and the VSES system activates, the drivers steering inputs combined with the differential braking will attempt to bring the delta velocity error toward zero.
The VSES activations generally occur during aggressive driving, in the turns or bumpy roads without much use of the accelerator pedal. When braking during VSES activation, the brake pedal will feel different than the ABS pedal pulsation. The brake pedal pulsates at a higher frequency during VSES activation.
Conditions for Running the DTC
The ignition is ON.
Conditions for Setting the DTC
C1287
One of the following conditions exists:
The steering wheel position sensor is synchronized and the steer rate (speed that the steering wheel appears to be turning) is greater than 1100 degrees/second.
The steer rate is less than 80 degrees/second and the difference in the phase angle between Phase A and Phase B is greater than 20 degrees.
The 2 steering sensor signals (Phase A and Phase B) do not agree for 1 second. Under this condition, this DTC will set along with DTC C1281.
C1288
Both Phase A and Phase B are greater than 4.9 volts for 1.6 seconds.
Both Phase A and Phase B are less than 0.2 volts for 1.6 seconds.
The difference in the changes in Phase A and Phase B is greater than 35.2 degrees for 9.76 milliseconds.
Action Taken When the DTC Sets
The EBCM disables the VSES for the duration of the ignition cycle.
The Traction Control and Active Handling indicator turns ON.
The DIC displays the Service Active Handling message.
The ABS remains functional.
Conditions for Clearing the DTC
The condition for the DTC is no longer present and the DTC is cleared with a scan tool.
The EBCM automatically clears the history DTC when a current DTC is not detected in 100 consecutive drive cycles.
Diagnostic Aids
The scan tool may display 2 additional characters after the DTC. Take note of the 2 character code and any other DTCs that are set. The 2 character code is an engineering aid used in order to determine the specific criteria which caused the DTC to set.
During diagnosis, park the vehicle on a level surface.
Check the vehicle for proper alignment. The car should not pull in either direction while driving straight on a level surface.
Find out from the driver under what conditions the DTC was set (when the DIC displayed the Service Active Handling message). This information will help to duplicate the failure.
The Snapshot function on the scan tool can help find an intermittent DTC.
Test Description
The numbers below refer to the step numbers on the diagnostic table.
Perform the Steering Position Sensor Test in order to verify if the steering wheel position sensor (SWPS) is operating properly.
Tests for the proper operation of the steering wheel position signal A circuit in the low voltage range.
Tests for the proper operation of the steering wheel position signal B circuit in the low voltage range.
Tests for the proper operation of the steering wheel position signal A circuit in the high voltage range. If the fuse in the jumper opens when you perform this test, the signal circuit is shorted to ground.
Tests for the proper operation of the steering wheel position signal B circuit in the high voltage range. If the fuse in the jumper opens when you perform this test, the signal circuit is shorted to ground.
Tests for a short to voltage in the 5 volt reference circuit.
Tests for a high resistance or an open in the low reference circuit.
Step
Action
Values
Yes
No
Schematic Reference: ABS Schematics
1
Did you perform the ABS Diagnostic System Check?
Go to Step 2
Go to Diagnostic System Check - ABS
2
Install a scan tool.
Turn ON the ignition, with the engine OFF.
With the scan tool, perform the Steering Position Sensor Test.
Did the SWPS pass the test?
Go to Diagnostic Aids
Go to Step 3
3
Turn OFF the ignition.
Disconnect the steering wheel position sensor (SWPS) connector.
With the scan tool, observe the Dual Analog SWPS Input A parameter in the VSES data list.
Does the scan tool indicate the Dual Analog SWPS Input A parameter is less than the specified value?
0.2 V
Go to Step 4
Go to Step 13
4
With the scan tool, observe the Dual Analog SWPS Input B parameter.
Does the scan tool indicate the Dual Analog SWPS Input B parameter is less than the specified value?
0.2 V
Go to Step 5
Go to Step 14
5
Connect a 3 amp fused jumper wire between the 5 volt reference circuit of the steering wheel position sensor (SWPS) and the signal A circuit of the steering wheel position sensor (SWPS).
With the scan tool, observe the Dual Analog SWPS Input A parameter.
Does the scan tool indicate that the Dual Analog SWPS Input A parameter is greater than the specified value?
4.9 V
Go to Step 6
Go to Step 10
6
Disconnect the fused jumper wire.
Connect a 3 amp fused jumper wire between the 5 volt reference circuit of the steering wheel position sensor (SWPS) and the signal B circuit of the steering wheel position sensor (SWPS).
Does the scan tool indicate that the Dual Analog SWPS Input B parameter is greater than the specified value?
4.9 V
Go to Step 7
Go to Step 10
7
Measure the voltage between the 5 volt reference circuit of the steering wheel position sensor (SWPS) and the low reference circuit of the steering wheel position sensor (SWPS).
Does the voltage measure less the specified value?
5 V
Go to Step 8
Go to Step 9
8
Disconnect the negative battery cable. Refer to Battery Negative Cable Disconnect/Connect Procedure in Engine Electrical.
Measure the resistance from the low reference circuit of the steering wheel position sensor (SWPS) to a good ground.
Does the resistance measure less than the specified value?
5 ohms
Go to Step 16
Go to Step 15
9
Test the 5 volt reference circuit of the steering wheel position sensor (SWPS) for a short to voltage. Refer to Circuit Testing and Wiring Repairs in Wiring Systems.
Did you find and correct the condition?
Go to Step 20
Go to Step 17
10
Test the 5 volt reference circuit of the steering wheel position sensor (SWPS) for the following conditions:
An open
A short to ground
A high resistance
Go to Step 20
Go to Step 11
11
Test the signal A circuit of the steering wheel position sensor (SWPS) for the following conditions:
An open
A short to ground
A high resistance
Go to Step 20
Go to Step 12
12
Test the signal B circuit of the steering wheel position sensor (SWPS) for the following conditions:
An open
A short to ground
A high resistance
Go to Step 20
Go to Step 17
13
Test the signal A circuit of the steering wheel position sensor (SWPS) for a short to voltage. Refer to Circuit Testing and Wiring Repairs in Wiring Systems.
Go to Step 20
Go to Step 17
14
Test the signal B circuit of the steering wheel position sensor (SWPS) for a short to voltage. Refer to Circuit Testing and Wiring Repairs in Wiring Systems.
Go to Step 20
Go to Step 17
15
Disconnect the EBCM harness connector.
Install the J 39700 universal pinout box using the J 39700-300 cable adapter to the EBCM harness connector only.
Test the low reference circuit of the steering wheel position sensor (SWPS) for a high resistance or an open. Refer to Circuit Testing and Wiring Repairs in Wiring Systems.
Go to Step 20
Go to Step 17
16
Inspect for poor connections at the harness connector of the steering wheel position sensor (SWPS). Refer to Testing for Intermittent and Poor Connections and Connector Repairs in Wiring Systems.
Go to Step 20
Go to Step 18
17
Inspect for poor connections at the harness connector of the EBCM. Refer to Testing for Intermittent and Poor Connections and Connector Repairs in Wiring Systems.
Go to Step 20
Go to Step 19
18
Replace the steering wheel position sensor (SWPS). Refer to Steering Shaft, Lower Bearing, and Jacket - Disassemble - Off Vehicle and Steering Shaft, Lower Bearing, and Jacket - Assemble - Off Vehicle in Steering Wheel and Column - Tilt.
Did you complete the repair?
Go to Step 20
19
Replace the EBCM. Refer to Electronic Brake Control Module (EBCM) Replacement .
Go to Step 20
20
Clear the DTCs using the scan tool.
Operate the vehicle within the Conditions for Running the DTC as specified in the supporting text.
Does the DTC reset?
Go to Step 2
System OK
Document ID# 670707
2002 Chevrolet Corvette
DTC C1287 or C1288
Circuit Description
The ignition is ON.
C1287
C1288
Diagnostic Aids
Test Description
Step
Action
Values
Yes
No
1
Go to Step 2
2
Go to Step 3
3
0.2 V
Go to Step 4
Go to Step 13
4
0.2 V
Go to Step 5
Go to Step 14
5
4.9 V
Go to Step 6
Go to Step 10
6
4.9 V
Go to Step 7
Go to Step 10
7
5 V
Go to Step 8
Go to Step 9
8
5 ohms
Go to Step 16
Go to Step 15
9
Go to Step 20
Go to Step 17
10
An open
A short to ground
A high resistance
Go to Step 20
Go to Step 11
11
An open
A short to ground
A high resistance
Go to Step 20
Go to Step 12
12
An open
A short to ground
A high resistance
Go to Step 20
Go to Step 17
13
Go to Step 20
Go to Step 17
14
Go to Step 20
Go to Step 17
15
Go to Step 20
Go to Step 17
16
Go to Step 20
Go to Step 18
17
Go to Step 20
Go to Step 19
18
Go to Step 20
19
Go to Step 20
20
Does the DTC reset?
Go to Step 2
System OK
Document ID# 670707
