Airbag disable kit?
Airbag disable kit?
Where do I get the airbag disable kit for the passenger side, and how do you install it? I'd like to take my little kids out for a cruise in the Vette.
Re: Airbag disable kit? (TOPGUN9)
There is no "kit" This is a feature that comes with the car. You can disable the passenger side air bag. Just open the glove compartment, you'll see a switch which you can turn with your key, and this will turn the passenger airbag off. :seeya
Received 1,295 Likes
2022 C1 of the Year Finalist - Unmodified
2021 C1 of the Year Finalist - Unmodified
2019 C1 of Year Finalist (stock)
2016 C1 of Year Finalist
There IS a kit for early C5's that did not have the disable switch. It's from GM. You can buy it from a GM dealer, or through Ken Fichtner (a GM dealer who does business with a lot of forum members). It includes a switch, a light, all the necessary wiring, and a NEW SEAT BELT.. Apparently, the belt needs to be changed because the stock belts have a break-away feature not desired when the airbag is disabled.
Go to the "Ken's newsletter" section to read all about it. http://forums.corvetteforum.com/zerothread?id=147175
[Modified by SDVette, 5:56 PM 9/10/2001]
Cruise-In IV Veteran
St. Jude Donor '03-'06-'08-'10-'11
I'm glad this was clarified, I was beginning to think that I've missed something in my 97 all this time. But there really is no switch there, I checked.
Yes you can and should add the air bag shut-off switch to 99's and earlier vettes. There are pictures of installation at http://www.97vette.com Ken's is the best place to order one. You might also want to get a form from the government saying they approve of you putting switch in. It is a fomality in case something would ever happen. There are previous posts on this address. Ken
Re: Airbag disable kit? (kenrobb)
A slight correction to kenrobb's post...you should add the kit to any Corvette built from December 1999 and earlier...the switch became standard in January 2000.
cc
cc
