what spark plug gap for H/C setup
Originally Posted by htvette
I am currently doing h/c setup. Is the spark plug gap the same as before (.050)? Thanks.
What type of plugs? Do you want to run nitrous with your new setup?
I went one range colder as recommended by NGK but switched to Denso Iridiums based on recommendations from Katech. I left them at 0.044" gap.
What heads, be aware that some of the LS1 heads have switched from a tapered plug seat to a gasketed one. Dart has done this.
Before h/c cam, I was using NGK TR-55's with .050 gap. The heads are 2.5 stage PRC ls6. Cam is TSP V2 torquer. I would like to use the same spark plugs. Thanks
