C5 coilover conversion
Old 12-22-2006, 11:49 AM
ernie27
Cruising
ernie27's Avatar
Default C5 coilover conversion
Is there any threads on C5 coilover conversions? I did a search but everything was for C4s. thanks
Old 12-22-2006, 11:59 AM
yellohvette
yellohvette's Avatar
I want to do this too, after i have more power mods
http://forums.corvetteforum.com/show....php?t=1535234
http://www.digitalcorvettes.com/foru...d.php?p=691863
http://www.digitalcorvettes.com/inde...racing-install
while it isn't the end-all of coilover stuff for the C5, it does look pretty straight-forward. Good Luck
Old 12-22-2006, 12:07 PM
Wicked Weasel
Wicked Weasel's Avatar
St. Jude Donor '05-'08
I am going to coilovers in January if you can wait that long
Old 12-22-2006, 12:13 PM
0EG@EnglandGreen
Supporting Tuner
Support Corvetteforum!
EG@EnglandGreen's Avatar
Location: ================== Houston, Texas www.englandgreen.com ================== Necessary Evil™ __________
CI 6-7-8-9-10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14
Check here for install with pictures...
http://forums.corvetteforum.com/show...p?p=1552762622
Old 12-22-2006, 02:12 PM
ernie27
Cruising
ernie27's Avatar
thanks, great info.
Old 12-22-2006, 05:03 PM
vmaquera
vmaquera's Avatar
Sorry for being dumb, but why are coilovers better than say Bilsteins?
Old 12-22-2006, 05:58 PM
John Shiels
John Shiels's Avatar
Location: Buy USA products! Check the label! Employ Americans
coil-overs replace the shock and the transverse springs. Better is always a fight here.
Old 12-22-2006, 10:22 PM
Wicked Weasel
Better?? Well it would be much better than your average set of shocks and your stock leaf springs.
Now can you get a set of shocks and springs to match that are better than coilovers- dam right you could. I guess in the end the advantage with the coiloverrs is being able to adjust them though I am not sure how many people actually take advantage of that.
Old 12-22-2006, 10:31 PM
0EG@EnglandGreen
Supporting Tuner
Bilsteins are just shocks. Coilovers replace the shocks and leaf springs
EG
Old 12-22-2006, 10:32 PM
DngrZne
DngrZne's Avatar
Just an FWI, several of the coil overs use Bilstein shock bodies
Old 12-22-2006, 10:51 PM
0Randy@DRM
Former Vendor
Randy@DRM's Avatar
There are about 4 different popular companies that do coilovers on the C5's. We are one of them and I like to think we are the best Many companies use the Bilstein shocks because they are great shocks for the money and are very servicable. We have been using them for years and years and years and would never go a different way, unless it is a full out racecar. Hyperco springs are also very good that is why we run them.
Randy
Old 12-22-2006, 10:52 PM
0EG@EnglandGreen
Supporting Tuner
Randy
The pic above is of DRM coilovers
Old 12-22-2006, 10:56 PM
0Randy@DRM
Former Vendor
Randy@DRM's Avatar
Hey EnglandGreen
I tried to call you back twice on Thursday. When you called I was sleeping in bed with the flu
Randy
Old 12-22-2006, 11:01 PM
0EG@EnglandGreen
Supporting Tuner
Hey EnglandGreen
Randy
Randy,
PM sent
Stephen
Old 12-24-2006, 08:32 PM
vmaquera
vmaquera's Avatar
Default Coilovers
Thank you gents.
As always, this forum is very educational. Since joining, I have learned a lot about things. Even if I might not use the "mod", such as the coilovers.
I think for now, I will stick with my Z51 and Bilsteins.
Thanks to all again.
To C5 coilover conversion
Quick Reply: C5 coilover conversion
