Replacing output shaft seal...any others??
Old 01-29-2007, 12:33 PM
pylant
pylant's Avatar
Default Replacing output shaft seal...any others??
I will be replacing the output shaft seal on the transmission sometime in the future. After I pull the transaxle is there any other seals that should/need to be replaced while I have it torn apart.
Old 01-30-2007, 11:57 AM
GREG O.
GREG O.'s Avatar
Default seals
withstupid: doing a 6speed r and r. need the same answers: maybe Steve at CT. IN Avon Ct can help!!!!!!!!!!!!!!!!!!!
Old 01-30-2007, 01:19 PM
Allthrottleandsomebottle
Support Corvetteforum!
Allthrottleandsomebottle's Avatar
Virginia Events Coordinator
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
NCM Ambassador
I would do the shaft seal on both sides............I just did mine.
Old 01-30-2007, 03:42 PM
pylant
pylant's Avatar
Ya, the shaft seals would be easy to do.
Where is this famous differential leak at that people talk about?
If I could head off a common leak that be great.
Right now I have and ATF leak so I really want to make sure I get all seals that can cause a leak changed on the transmission. I know about the output shaft seal. Are there others??:?
Old 01-30-2007, 07:16 PM
pylant
pylant's Avatar
Was wondering if anyone has ever used ATV with these seals?
Old 01-30-2007, 09:19 PM
bobc997615
bobc997615's Avatar
There's a "o-ring" seal around the perimeter of the seal plate that the rear seal installs into, but it is usually never a problem.
Old 01-30-2007, 10:18 PM
GREG O.
GREG O.'s Avatar
Default seals
so thats all the seals and ring seals i need to r & r 6 speed??
Old 01-31-2007, 04:53 AM
bobc997615
bobc997615's Avatar
Yup, just a major rear end/suspension pull to fix an output shaft seal. But it's a great time to install a new cat-back exhaust since the mufflers are so easy to remove.
Old 01-31-2007, 08:46 AM
pylant
pylant's Avatar
Ohhhh...the possibilities.
Old 01-31-2007, 08:24 PM
MikeV
MikeV's Avatar
If you punish this thing with high RPM launches and sticky tires, this is the time to replace the long shaft while you have it out!!!
Mike V
Old 02-03-2007, 10:01 PM
pylant
pylant's Avatar
Still wondering what the famous diff leak is?
Is it the seals for the drive shafts or the diff cover O rings or something else?
Old 02-03-2007, 10:24 PM
MikeV
MikeV's Avatar
It was the shaft seals... They changed the part number and went to a new style that fixed the problem...
Mike V
Old 02-04-2007, 01:14 AM
GREG O.
GREG O.'s Avatar
Default shaft seals
Mike V
i'm almost ready to swap out 6 speed's. when i bought this frc a year ago it had 15,000 mile on the new 410,s. nothing leaks nada! should i stick with the old seals or replace?? thanks anyone??
Old 02-05-2007, 07:08 AM
Cruise-In V Veteran
NCM Ambassador
Actually,the big leak is the poorly machined o-ring groove by Getrag........
Here is the TSB with GM part numbers:
Here is a copy of the TSB if you need it.
Document ID# 1826526
2003 Chevrolet Corvette
Subject: Fluid Leak at Rear Axle (Replace Left Differential Side Cover O-Ring and Left Axle Shaft Seal, Add Sealant to Side Cover Flange) #03-04-20-006A - (05/09/2006)
Models: 2004-2005 Cadillac XLR
1997-2005 Chevrolet Corvette
This bulletin is being revised to add the 2005 model year and provide VIN breakpoints. Please discard Corporate Bulletin Number 03-04-20-006 (Section 04 -- Driveline/Axle).
Built Prior to the Following VIN Breakpoints:
Model
VIN
Cadillac XLR
55603770
Chevrolet Corvette
55122600
Condition
Some customers may comment on fluid leaking from the rear axle.
Correction
Verify that the fluid leak is rear axle fluid, not transmission fluid. Replace the left differential side cover O-ring and left axle shaft seal. Engineering has recommended that sealant be applied to the side cover prior to installation. Use the appropriate service procedure and part numbers listed below.
Service Procedure (Cadillac XLR)
Raise and support the vehicle.
Remove the rear tire and wheel assemblies.
Install J 33432-A Transverse Spring Compressor to the rear transverse spring and compress the spring.
Disconnect the electrical connectors from both wheel speed sensors.
Disconnect the electronic suspension control (ESC) position sensor links, if equipped.
Disconnect the shock absorber solenoid electrical connectors, if equipped.
Remove the brake calipers from the caliper mounting brackets and support aside.
Remove the outer tie rod end nuts.
Disconnect the outer tie rod end studs from the rear suspension knuckles.
Disconnect the park brake cables from the park brake apply levers and brackets.
Remove the shock absorber lower mounting bolts from the lower control arms.
Remove the bolts securing the upper control arms to the frame.
Remove the spindle nuts retaining the rear wheel axle shafts to the hubs.
Rotate the suspension knuckles until the axle shafts clear the hubs.
Disconnect the wiring harness and brake pipe clip retainers from the rear suspension crossmember.
Release brake pipes from underbody clips.
Remove the transaxle mount to rear crossmember nuts.
Position an adjustable jack stand under the transmission and support the transmission.
Position a transmission jack under the rear suspension crossmember and firmly secure the crossmember to the jack.
Remove the rear suspension crossmember mounting nuts.
Slowly lower the rear suspension crossmember away from the vehicle frame rails and remove the crossmember.
Release and remove the rear wheel axle shafts from the differential.
Remove the intermediate exhaust pipe.
Remove the left muffler.
Drain the rear differential fluid. Refer to the Lubricant Change procedure in the Rear Axle sub-section of the Service Manual.
Remove the left differential mount.
Clean any dirt or debris from around the differential cover.
Remove the bolts retaining the differential cover.
Remove the differential cover from the differential.
Remove and discard the O-ring seal and the axle seal from the differential cover.
Clean the O-ring sealing surface on the differential cover and the differential housing.
Install new O-ring, P/N 89047953, to the differential cover.
Apply a continuous 3 mm (0.125 in) bead of sealant, P/N 1052942 (Canadian P/N 10953466), or equivalent, to the cover flange.
Apply sealant around the bolt holes. Keep sealant away from the O-ring.
Install the differential cover to the differential.
Install the differential cover retaining bolts.
Tighten
Tighten the bolts to 28 N·m(20 lb ft).
Clean the excess sealant from the left cover/housing splitline.
Install the new axle seal, P/N 88996703, into the differential cover using J 46405.
Install the left differential mount.
Install the left muffler.
Install the intermediate exhaust pipe.
Install the rear wheel axle shafts to the differential.
Install the rear suspension crossmember.
• Align the crossmember dowel pins to the holes in the frame rails.
• Align the transaxle mount studs to the crossmember.
Install the rear suspension crossmember mounting nuts.
Tighten
Tighten the crossmember mounting nuts to 110 N·m(81 lb ft).
Remove the transmission jack from the crossmember.
Remove the adjustable jack stand from under the transmission.
Install the transaxle mount to rear crossmember nuts.
Tighten
Tighten the transaxle mount nuts to 50 N·m(37 lb ft).
Connect the wiring harness and brake pipe clip retainers to the rear suspension crossmember.
Install the brake pipes to the underbody clips.
Install the spindle nuts retaining the rear wheel axle shafts to the hubs.
Tighten
Tighten the spindle nuts to 160 N·m(118 lb ft).
Install the bolts securing the upper control arms to the frame.
Tighten
Tighten the upper control arm bolts to 110 N·m(81 lb ft).
Install the shock absorber lower mounting bolts to the lower control arms.
Tighten
Tighten the shock absorber lower mounting bolts to 220 N·m(162 lb ft).
Connect the park brake cables to the park brake apply levers and brackets.
Connect the outer tie rod end studs to the rear suspension knuckles.
Install the outer tie rod end nuts.
Tighten
• Tighten the outer tie rod end nuts to 20 N·m(15 lb ft) to seat the outer tie rod studs.
• Turn the nuts additional 160 degrees.
• Check the outer tie rod end nuts for a minimum torque of 45 N·m(33 lb ft).
Install the brake calipers to the caliper mounting brackets.
Tighten
Tighten the brake caliper guide pin bolts to 31 N·m(23 lb ft).
Connect the shock absorber solenoid electrical connectors, if equipped.
Connect the electronic suspension control (ESC) position sensor links, if equipped.
Connect the electrical connectors to both wheel speed sensors.
Remove J 33432-A Transverse Spring Compressor from the rear transverse spring.
Install the rear tire and wheel assemblies.
Refill the rear differential fluid. Refer to the Lubricant Change procedure in the Rear Axle sub-section of the Service Manual.
Lower the vehicle.
Service Procedure (Corvette)
Remove the left rear tire and wheel assembly.
Disconnect the electrical connector from the left wheel speed sensor.
Disconnect the electronic suspension control (ESC) position sensor link, if equipped.
Disconnect the shock absorber solenoid electrical connector, if equipped.
Remove the outer tie rod end nut.
Disconnect the outer tie rod end stud from the rear suspension knuckle.
Disconnect the park brake cable from the park brake apply lever and bracket.
Remove the spindle nut retaining the rear wheel axle shaft to the hub.
Rotate the suspension knuckle until the axle shaft clears the hub.
Release and remove the rear wheel axle shaft from the differential.
Remove the retaining bolts and the damper/tuned absorber from the differential (97-04 model years).
Loosen the nut retaining the transmission to the transmission LH mounting stud.
Install a second nut onto the stud.
Remove the stud from the differential cover.
Tighten
Using two nuts installed on the stud, install the transmission mounting stud to the differential cover.
Tighten
Tighten the stud to 42 N·m(31 lb ft).
Remove the second nut from the transmission mounting stud.
Tighten the nut retaining the transmission to the transmission LH mounting stud.
Tighten
Tighten the nut to 50 N·m(37 lb ft).
Install the damper/tuned absorber and bolts to the differential (97-04 model years).
Tighten
Tighten the bolts to 25 N·m(18 lb ft).
Install the new axle seal, PN 88996703, into the differential cover using J 46405.
Install the rear wheel axle shaft to the differential.
Install the spindle nut retaining the rear wheel axle shaft to the hub.
Tighten
Tighten
Connect the park brake cable to the park brake apply lever and bracket.
Connect the outer tie rod end stud to the rear suspension knuckle.
Install the outer tie rod end nut.
Tighten
• Tighten the outer tie rod end nut to 20 N·m(15 lb ft) to seat the outer tie rod stud.
• Turn the nut additional 160 degrees.
• Check the outer tie rod end nut for a minimum torque of 45 N·m(33 lb ft).
Connect the shock absorber solenoid electrical connector, if equipped.
Connect the electronic suspension control (ESC) position sensor link, if equipped.
Connect the electrical connector to the left wheel speed sensor.
Install the left rear tire and wheel assembly.
Lower the vehicle.
Parts Information
Part Number
Description
Qty
88996703
Seal, Output Shaft Oil
1
89047953
O-Ring, Differential Side Cover
1
1052942 (Canada 10953466)
Sealant
1
Warranty Information
For vehicles repaired under warranty, use:
Labor Operation
Description
Labor Time
F9701* (XLR Only)
Rear Axle Seal Replace -- Side Cover and Axle Shaft
2.3 hrs
F9701* (Corvette Only)
1.6 hrs
*This is a unique labor operation for bulletin use only. It will not be published in the Labor Time Guide.
GM bulletins are intended for use by professional technicians, NOT a "do-it-yourselfer". They are written to inform these technicians of conditions that may occur on some vehicles, or to provide information that could assist in the proper service of a vehicle. Properly trained technicians have the equipment, tools, safety instructions, and know-how to do a job properly and safely. If a condition is described, DO NOT assume that the bulletin applies to your vehicle, or that your vehicle will have that condition. See your GM dealer for information on whether your vehicle may benefit from the information.
WE SUPPORT VOLUNTARY TECHNICIAN CERTIFICATION
© Copyright General Motors Corporation. All Rights Reserved.
Greg O, if the shaft seal metal outside face has rust on it...if you drive it hard (10K miles a year, lots of racing ~50-60+ passes a year)........I would put new ones on.....rust means to me the seal is old and been on a while like this one(3+years):
Old 02-05-2007, 05:23 PM
MikeV
MikeV's Avatar
Thats the one... I think I copied it in January of '04.
Mike V
Old 02-07-2007, 09:08 PM
pylant
pylant's Avatar
okay, we have narrowed down the famous diff leak to primarily being the left side O ring and axle seal.
Now, how about the transmission. What seal is causing my ATF leak?
Can it only be the output shaft seal? Is there any other seal that anywould would recommend replacing while in there or is the output shaft seal all that need to be done? Don't want to be replacing things just to be replacing them but sure don't want to be taking out the rear of the car anytime soon after replacing the output shaft seal.
thanks,
Old 02-07-2007, 10:15 PM
LoneStarFRC
LoneStarFRC's Avatar
Location: Dear Karma, I have a list of people you missed.
thanks,
For a lot of guys it's turning out that it's not the trans output shaft seal so much, but rather the leak comes from in between the main transmission case and the rear "extension housing" (sandwiched between the trans and differential) They are just two flat machined surfaces and are bolted together. Don't think GM even used a gasket there originally, maybe RTV. Mine used to leak from there, but MTI was able to use RTV and it has not leaked for at least two or three years now.
HTH,
Robert
To Replacing output shaft seal...any others??
Old 02-07-2007, 10:30 PM
Mike Mercury
Mike Mercury's Avatar
89047953 (new revision) side plate outer "O" ring seal (use with anerobic sealer) List $21.50
88996703 (new revision) output shaft(s) center seal List $18.01
89021677 - part number for the anerobic sealer Price ???
and the A4 has a "seal plate" that keeps the rear axle fluid from leaking forward (between the tranny and carrier). it has two seals itself:
Carrier tranny center-shaft seal (A4): 24207010 list $10.96 (newer substitute PN: 24228816 )
Seal Plate O-ring (A4): 12369456 List $10.75
Old 02-07-2007, 11:52 PM
GREG O.
GREG O.'s Avatar
nice pics, great read thanks GREG O.!!!
Old 02-08-2007, 11:48 AM
pylant
pylant's Avatar
HTH,
Robert
Stange...just can't see how ATF fluid could be leaking and it not be a seal/gasket. Now RTV may help seal up and area from leaking put the root cause should be a bad seal.
Any thoughts on which seal this could be??
tks
Quick Reply: Replacing output shaft seal...any others??
