G5X3 Cam....114 LSA or .112 LSA??
Old 01-31-2007, 09:57 PM
1kwikvette
1kwikvette's Avatar
Default G5X3 Cam....114 LSA or .112 LSA??
Installing intake, G5x3 Kit and LG Longtubes, what LSA should I go with??
Old 01-31-2007, 10:02 PM
Wicked Weasel
Wicked Weasel's Avatar
St. Jude Donor '05-'08
personally I like the 114LSA. The car still has the feel of a cam in it, but your teeth are not rattling out of your mouth.
Old 01-31-2007, 10:05 PM
happa
happa's Avatar
112 if you like the hot rod lope!
Old 01-31-2007, 10:06 PM
1kwikvette
1kwikvette's Avatar
I actually like that! My last vette had to be put in neutral so it would idle at a stop light.
Old 01-31-2007, 11:11 PM
Mopar Jimmy
Mopar Jimmy's Avatar
Location: Elmhurst, IL (West Suburb of Chicago) & Home of MEGA Horsepower
St. Jude Donor '06
Go with the 112 if you like the very aggressive hot rod choppy idle sound and 114 is you want to be a little more stealth!!
Old 02-01-2007, 07:46 AM
Blown 346
Blown 346's Avatar
That right there is awesome.
Old 02-01-2007, 07:55 AM
Wicked Weasel
then the 112 would be your answer.
Old 02-01-2007, 08:42 AM
KidCid
KidCid's Avatar
CI 7-8 Veteran
Of course he could always do 111 or 110 if he REALLY wanted to feel it.
CorvetteBrent (08-14-2018)
Old 02-01-2007, 09:30 AM
Wicked Weasel
he better not have anything in his bladder then
Old 02-01-2007, 10:08 AM
Cobra4B
Cobra4B's Avatar
CI 3-5-6-7-8 Veteran
Here's my G5-X2 on a 114 (click the pic to view the movie)
I went 114 because I still almost daily drive the car
Old 02-01-2007, 02:07 PM
NeverT00Fast
NeverT00Fast's Avatar
How much advance was ground into the cam? +2?
Old 02-01-2007, 02:09 PM
Cobra4B
Cobra4B's Avatar
It's +4
Old 02-01-2007, 04:16 PM
Jeffs FRC
Jeffs FRC's Avatar
My cam is on a 110 and it doesnt rattle my teeth out at all. Car has a nice shake to it at idle. Go for the 112.
Old 02-01-2007, 05:56 PM
Darkhalf
Darkhalf's Avatar
I would have gone with the 112, but I have read so many stories even some from Lou/Louis that with the 112 you'd have to flycut the pistons. Which is why I went with the 114 instead. Plus your power band comes on quicker
Old 02-01-2007, 06:04 PM
NeverT00Fast
Actually, power comes on quicker when you go tighter on the LSA.
Old 02-01-2007, 06:23 PM
bfhawki
bfhawki's Avatar
St. Jude Donor '06
I did a head/cam swap last Nov. I put in a 228/232 .588/.595 111+1. It had a nice sounding idle but really shook the car hard at idle. I left it in for about a month. I took it out and put in a 224/228 .581/.588 114+2. The new cam drives so much better than the 1st one did. It still shakes a little bit, but nothing like the 1st one did. You can still tell that there is a cam in the car with the new cam. I can drive the new cam down around 1000 rpm in any gear without surging or bucking. I don't feel like I lost a lot of hp. I am more than willing to give up a few hp for a better driving car.
Old 02-01-2007, 08:06 PM
1kwikvette
1kwikvette's Avatar
From Anthony at LG:
Personally unless the cars are side by side, I can't tell the difference in idle. The 112 will make it's peak power numbers 500 rpm lower in the power band but they both should make the same power.
There is no reason you should have to worry about putting anything in neutral at a light as long as the car is tuned right and it has the correct stall (if it's an auto car).
If you don't mind the idle....a 112 would make it's peak more in the streetable rpm range.
To G5X3 Cam....114 LSA or .112 LSA??
Quick Reply: G5X3 Cam....114 LSA or .112 LSA??
