Fuse box Cover screw-removal?
Old 02-13-2007, 11:51 PM
99TorchTop
99TorchTop's Avatar
Default Fuse box Cover screw-removal?
How do you remove the plastic screw from the top of the fuse box cover? I'm trying to put a top cover on it and not sure how it comes out? Scott
Old 02-14-2007, 01:31 AM
LF97C5Vette
LF97C5Vette's Avatar
Lets see... righty tighty, lefty loosey?
GJ Problem solved!
Just kidding if you couldn't tell. I'm sure you mean remove the screw entirely from the lid - at which i have no experience. Good Luck
Dan
Old 02-14-2007, 10:27 AM
mrm1149
Support Corvetteforum!
mrm1149's Avatar
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13
From memory, there is a plastic piece that would remind you of a wall anchor that the threads go into...slit that plastic piece with a razor blade and out it comes! I think I used a small electrical tie to close the plastic anchor after I put my stainless cover on.
Old 02-14-2007, 01:12 PM
SLPRC5
SLPRC5's Avatar
Originally Posted by dndrsn
Very neat "how to" video
Old 02-14-2007, 01:35 PM
screw991le
screw991le's Avatar
Location: Redsox, Pats, Celts & Bruins !!! Redsox Nation !!!
Cool video.
Old 02-14-2007, 11:24 PM
99TorchTop
99TorchTop's Avatar
Thanks...most everyone understood the question!
Old 03-08-2014, 08:07 PM
EUROPLATECONCEPTS
5th Gear
EUROPLATECONCEPTS's Avatar
Flip the cover on its back.Pull lightly on the bolt while pushing the bolt to the none indented edge and pushing a flat mini screw driver against the plastic bolt and the molded clip.If you look at the bolt with a flash light you will see the bolt has a molded ring.The box has a molded clip which you can see with a light.Your goal is to push the plastic clip outward.No cutting 5 seconds its out.
Cheers
Old 03-08-2014, 10:05 PM
LoneStarFRC
LoneStarFRC's Avatar
Location: Dear Karma, I have a list of people you missed.
Cheers
I'm quite confident he got the answer to his question 7 years ago.
Old 03-09-2014, 01:05 PM
EUROPLATECONCEPTS
5th Gear
[QUOTE=LoneStarFRC;1586356809]I'm quite confident he got the answer to his question 7 years ago.[/QUOTE
I searched the net to figure out how to remove the bolt.The answer to do it on this site ruined the part by hacking it up.My ride is a mint condition 2002 Corvette ...not a Chevette
To Fuse box Cover screw-removal?
Quick Reply: Fuse box Cover screw-removal?
