MAP Sensor Gremlins (code P0107)
After replacing my oil pressure sensor this weekend in my 99, I get the code P0107 Manifold Pressure (MAP) Sensor Circuit Low Voltage. Any idea what I need to look for since I previously did not get this code? A circuit diagram will help. Is the sensor on the MAF or back of the intake?
Is there a procedure test the sensor?
Thanks in advance.
Charles
Thanks in advance.
Charles
Why would you ask something as simple as if I plugged it in. Of course I didn't plug it back in. Thanks Vettenuts thats what it was. You're the coolest and I owe you a beer. Now the hard part is getting to it without taking it back apart for the THIRD time. The second time was because of that stupid little vaccum tube .
Got it plugged in and no codes.Thanks again
