Will 02-04 Z06 EXHAUST MANIFOLDS fit on my 2000 A4 C5???
Hey there,
I was wondering if exhaust manifolds from a 2002-2004 Z06 will fit on my A4 2000 C5, since in this one year, the exhaust manifolds have a different AIR setup and may be a little shorter in overall size. Will i need to modify the Z06 exhaust manifold in anyway, and if so what needs to be done???? Also, how much power will those years cast Z06 exhaust manifolds yield over B&B shorty headers????
thanks alot everyone in advance
-Dave
-Dave
Hey there,
-Dave
-Dave
Z06 engines had higher compression, different cam, intake manifold, exhaust manifolds, valves and springs.
Save your money for LT headers
Yes, you are very right. However i read a couple posts that have said those years of Z06's have cast manifolds and a much better design over the stainless, shorter manifolds only found on 2000 C5's. I have also read that this switch alone can add 5-8rwhp to 2000 C5's. I dont know if this is all true, but it must be to an extent.
thanks alot
-Dave
I have just found out that i may have manifolds from the 97-99 C5's because of the fact thati do not have pup cats. The manifolds on my car do have a stainless steel cover on them also.... Does all this information seem to line up??? The 97-99 manifolds came with this stainless steel cover over the manifolds and no pup cats??? If that is the case, do i have to buy aftermarket shorties for the years 97-99 C5's???
thanks everyone
-Dave
thanks everyone
-Dave
