Does someone has 238/242 with Dart heads
Does someone has this set up?
Dart pro 1 heads 225cc and 64 cc combustion chamber
2.08"-1.6" valves
Cams 238/242 112LSA .605" and .605" opening
Match LS6 manifold and ported throttle body
with LGM headers and Vararam
will I be ok in 1st gear? or I will need to spin the clutch a lot
2.08"-1.6" valves
Very close to my setup.
Custom Crower cam 238/246 .622/.609 112+4
DART 225 milled to 61cc
LS6 intake/PP TB
LG Pro Long Tubes
Vararam
LS2 stroker 408 cubic inches
With 3:42's Wheel spin is not an issue, but I rarely drag race.
LS6 intake/PP TB
LG Pro Long Tubes
Vararam
Crower has their proprietary lobe designs and he basically fed my intake and head flow data into his computer program and it spit out a range of lobe choices allowing me to choose depending on my usage, and offered me 2 choices of lsa. It is a custom ground cam. Did he use all your flow data to come up with your cam?
This cam gave a very wide and flat torque curve which benefits road racing but sacrifices slightly on top end hp. My car dynoed at 480/480 but will increase about 20-30 more hp/tq with a better flowing bigger intake.
I for one am very happy with this cam. Are you?
dr chi;; is t5he oil cooler necessary for the track.
so far the oil temp was ok but I'm afraid it may a problem as the efficiency of the engine will drop and the heat will rise
I was seeing oil temps over 300 degrees before and I would have to take a couple of cool down laps. Now the highest I've hit during mid summer in FL is 276 no matter how long or hard I run.
276 is still a bit on the high side. 250-260s or lower would be better.
What oil are you running ? 15-w50?
some times the seperate oil cooler, put in front of the A/C condesor cools a bit better then the combo. Combos still work great, so there are several options.
Trans cooler ( left ) oil cooler ( right
