Wiper removal
Former Vendor
St. Jude Donor '07-'08-'09-'10-'11-'12'-'13-'14-'15
Wiper removal
How do I get the windshield wipers off? I removed the nuts from the top of the wipers but they are still stuck on there and will not budge. There has to be a trick to it? Thanks in advance.
Cajun
Cajun
Cajun: Run your wipers up onto the windshield first then shut them off "mid-wipe". Mark their position with some masking tape on the windshield. Getting the right position when re-installing is easy.
To avoid putting stress on the wiper arm shaft, I would use a small puller. There are special pullers made for this, or as already mentioned, you can use an old style top post battery terminal puller.
