DIC error code
DIC error code
There used to be a page somewhere in the CF which listed all the error codes and what you need to delete the history from your Driver Information Center.
Specifically, I didn't tighten up the gas cap until the ratchet kicked in on my Z06 and now the check engine light comes on. Does anyone have the link here to this page? I've used it before but can't seem to find it now. Thanks PT
Received 2,180 Likes
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Yep,,here ya go:
This is the absolute best C5 Diagnostic Trouble Code (DTC) web site!!!
http://www.corvettedoctor.com/Code_Main.html
http://www.corvettedoctor.com/index.html
Go to “technical data base” and then to “Corvette ECM Computer Codes”. Then select your year car. Read the instructions and then scroll down to the "READ MORE" window to view the code definitions.\
Here is another very good site:
http://www.obd-codes.com/trouble_cod...d-ii-codes.php
Make sure to include the H or C suffix!!
Write down and post your DTC’s Then clear them ALL!
Sound effects are cool too!
