Cam selection, stock heads
Old 05-19-2007, 07:31 AM
Tom Porter
Tom Porter's Avatar
Default Cam selection, stock heads
What would be the best cam selection with the stock heads?
Old 05-19-2007, 08:18 AM
ter
ter's Avatar
Here is a good link to read. http://www.ls1tech.com/forums/showthread.php?t=327734
I was looking a 5.3 heads, and a TR224 cam. I still need to do some more research. I was wondering if I could drop in a 224 with stock heads while I save up for heads and headers myself. From what I read, the TR224 is very popular for street manners, and nice flat power band. Headers before cams, is a popular statement, I don't know myself. The cam question seems to lead to headers, heads, underdrive pully, oil pumps, rods, tuning. It really adds up. $4000 budget? Funny how it starts with a $400 cam.
Old 05-19-2007, 11:16 AM
Pwrtrip75
Pwrtrip75's Avatar
you can go wild or mild depending on your application. what do you want your car to do? what stall? gears?
Old 05-19-2007, 12:01 PM
phils C5 vette
phils C5 vette's Avatar
St. Jude Donor '12-'13-'14
This was suggested to me, and I didnt follow it. I still think it's correct advice:
Do your homework and select the cam that's right for you, Then go one size bigger.
Old 05-19-2007, 12:45 PM
_Will_
_Will_'s Avatar
Location: Somewhere between mild insanity and complete psychosis
Go with the TR 224, or the TSP 224 or 228.
In fact, the TSP 224 is available on 116lsa, and has lift numbers in the 580s. So that cam would be extremely streetable with the wide lsa, make just about as good power as the tr224, and later on down the road when you add high-flow heads the nice high lift numbers just under .600 will better take advatage of ported heads. (The tr224 has lift in the .550s or .560s I believe.
Old 05-19-2007, 01:26 PM
Arcane1
Supporting Tuner
Arcane1's Avatar
Cruise-In VIII Veteran
St. Jude Donor '06-'07
I am in favor of the EnglandGreen Whiplash cam but then again I guess I am a little bit bias....
Old 05-19-2007, 09:05 PM
ter
ter's Avatar
Will,
I really don't know, but is the .550 number verses the .600 the lift on the springs? Maybe I'm wrong, but I was assuming that the .550 lift was better for the spring life. I guess it is all about trade offs, but I was willing to give up a few horsepower, to get long spring life, low end torque, factory idle in an A4. Anyhow, I am enjoying my first real look at cam/head selection. Thanks.
Old 05-19-2007, 10:00 PM
Z06PSI
Z06PSI's Avatar
St. Jude Donor '17-'18-'19
Basically yes. It is the lift of the cam lobe which affects springs and two things shorten spring life. Lift and ramp.
Old 06-13-2007, 12:50 AM
rikhek
rikhek's Avatar
ttt
Old 06-15-2007, 07:59 PM
0EG@EnglandGreen
Supporting Tuner
Support Corvetteforum!
EG@EnglandGreen's Avatar
Location: ================== Houston, Texas www.englandgreen.com ================== Necessary Evil™ __________
CI 6-7-8-9-10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14
Depends on your driving style, what you want from your car, and what are your ultimate performance goals.
Give us a call to discuss.
Stephen
To Cam selection, stock heads
Quick Reply: Cam selection, stock heads
