Amsoil SVG synthetic gear lube
For those of you who have used this, did you have to also use the GM or Amsoil additive? The Amsoil web site says you don't have to unless your diff starts to chatter.
It looks like Sub answered this question already, but I am curious as to the experience of other Amsoil gearlube users.
Thanks,
Dave
Thanks,
Dave
Premium Supporting Vendor
Dave,
As it looks like you saw on another post, I don't use the additive in my Z06 either and I've never experienced diff chatter.
__________________
C66 Racing #66 NASA ST2, SCCA T2
AMSOIL Dealer (Forum Vendor)
AMSOIL Ordering Information (Retail sales using reference #1206638 benefit the forum.)
AMSOIL Preferred Customer Program (Members buy at Wholesale - a savings of about 25%)
AMSOIL Catalog
AMSOIL Catalog
It can make your gear lube too slippery in that the clutch disks in your limited slip differential slip too much and make the likelyhood of encountering the one wheel spin in straight line operation greater. The optimum way to add limited slip additive is add just enough to eliminate the moaning, groaning, or chatter noises from the clutch disks. If your LSD is quiet, then no more should be added.
Hammer
Hammer
No extra here either. As a matter of fact, I just dumped it the other day to install my DTE rear. I drained the factory fill at 1,000 miles and replaced with Amsoil. I then changed again at 10K miles. The other day I dumped it and it was still blue like the day it went in, not black like rear oil usually gets. I think it was doing a very good job protecting the rear end.
Thanks, everyone. I ordered some on Sunday and wanted to be sure I didn't need the additive. Someone mentioned that 2 pints (1 quart) is all you need. Is that what you guys used?
Location: Edmond, OK...One of the first rules of online forums: If you don't like what is said but can't refute it, attack the poster.
1 Post
Is it better to break in a new Diff with conventional fluid and the additive, then change it after 500-1000miles to the amsoil?
jeff
jeff
Hammer
Hammer
And, actual diff capacity is about 1.7 quarts, so as Hammer also said, you'll need two quarts, not one.
