Wiper Motor Removal Procedures
Old 05-27-2007, 01:12 PM
Bville-Bud
Support Corvetteforum!
Bville-Bud's Avatar
St. Jude Donor '05-'06-'07-'08
Default Wiper Motor Removal Procedures
I had to replace my wiper motor, and thought I’d post my procedures. I’ll post up the pictures tonight. The whole process wasn’t very hard, but the wiper arms were a real bear to get off the arm studs.
Tools Needed:
Hammer
Needle Nose Pliers
Small Common Screwdriver
Regular Common Screwdriver
T20 Torx
T30 Torx
Small Puller (I used a battery terminal puller)
Ratchet
Socket (10 MM Metric)
Socket (1/2 SAE)
5 inch extension
Parts Needed:
Wiper Motor
Removal
1. Remove 25 amp windshield wiper fuse (fuse 10) in the passenger’s side fuse box.
2. Disconnect the windshield washer hoses from the wiper arms.
3. Remove screen tray connectors by prying the center the center section of the connector with a small screwdriver; this center section spreads the connector feet keeping the connector locked in. Take needle nose pliers and remove the outer casing.
4. Use a small screwdriver and remove windshield wiper arm nut caps. Use caution not to mar the wiper blade finish. The nut is very tight, penetrating oil sprayed onto the connecting nut will facilitate the nut removal. Remove the ½ nut underneath the cover.
5. Remove the wiper arm by using small puller, to press the wiper stud and pull up the wiper arm.
6. Carefully pull the wiper valley cover tray away from the windshield, start by pulling the corners free, where there is very little clearance between the windshield and the top corner of the fenders. Work from the corners to the center section.
7. Flip the cover over and rest on top of engine, be careful not to break the washer hose etc. This will expose the wiper transmission linkage, and the wiper motor attached to the linkage in the drivers corner of the wiper valley.
8. Remove the two 10 MM wiper transmission bolts on driver’s side.
9. Remove the 10 MM wiper transmission bolt on passenger side.
10. Remove the T30 Torx screw and lift the motor arm that connects the wiper transmission to the top of the motor.
11. Remove the three T30 Torx screws that hold the motor to the wiper transmission.
12. Carefully work the transmission free to expose the wiper motor, and move away from wiper valley. Use care not to damage the transmission arms during removal or storage.
13. Take wiper motor out of valley and turn the motor over, use a small common screwdriver to depress the locking catch, and remove the electrical plug from the motor.
14. Clean any debris out of the three rubber drain channels (udders).
15. Remove T20 Torx screw, and separate the wiper motor plate and rubber shield from the wiper motor.
The following 4 users liked this post by Bville-Bud:
Corvette4Life_01 (12-08-2019), jlonardo1962 (06-15-2021), NealinAZ (10-13-2021), OVRPWRD (03-15-2020)
Old 05-27-2007, 05:02 PM
Bville-Bud
Bville-Bud's Avatar
Added pics, don't forget to get yourself an expert crew chief to help with the project:
Old 05-27-2007, 05:51 PM
MadTom
MadTom's Avatar
Great job and damn well documented .
Did you modified the outlet of the three udders? Imo they are miserable constructed.
My wiper motor was awash and I found the three rubber drain channels (udders) blocked with mud and leaves. The lower port of the udders are miserable constructed.
I enlarged the outlet yesterday. Now the water and dirt will be will be sluiced down.
Tom
Old 05-27-2007, 05:56 PM
Bville-Bud
Bville-Bud's Avatar
Tom
Thanks, glad you liked it. I did open up the bottom of the udders some .
Old 09-26-2007, 10:35 PM
RedRider98
RedRider98's Avatar
This will come in handy. Thanks for taking the time to take pics!
Old 04-22-2008, 02:49 PM
Bill Curlee
Bill Curlee's Avatar
Received 2,180 Likes on 1,583 Posts
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Old 04-24-2008, 11:12 PM
KiwiToni
KiwiToni's Avatar
gotta love this forum! hubby is now outside trying to clean his udders! we need the car sunday, and don't want the wipers going when they shouldn't, but we also want them to work when they should!
thanks for the help!
Debs
Old 05-17-2008, 02:14 PM
valdeztke
valdeztke's Avatar
A god send!
Old 05-17-2008, 03:30 PM
thetaxman
thetaxman's Avatar
good write up
my wipers came off easily, I guess I got lucky
Old 05-18-2008, 03:41 AM
tstar
tstar's Avatar
St. Jude Donor '11-'12-'13-'14-'15
Excellent write-up!!! I had to stumble through this last year, and this would have been very helpful!! Turned out the cam on top was not installed correctly and my wiper motor was actually good! So pay attention to how the cam is oreinted before you remove it...
FYI I believe the closed end design on the udders is to keep rodents out of the blower motor/cabin...
Old 08-30-2008, 02:00 PM
NY~FX
NY~FX's Avatar
great writeup
- Just one Note - DON"T buy that POS puller, mine broke after pulling drivers side - what crap from Taiwan - get a better one or you will regret it.
Old 02-01-2009, 10:25 PM
VETTHOG
VETTHOG's Avatar
I followed the instructions shown here, installed a new motor and everything went alright until I started the wipers and they don't work like they should Does anyone know What I did wrong?
Old 02-01-2009, 11:03 PM
c5blkvetteguy
c5blkvetteguy's Avatar
Are your wipers in the wrong spot when they are in the park position (when delay is on)? Cam on the wiper motor is out of position. Mine is the same way. It will be my spring fix.
Old 02-01-2009, 11:37 PM
VETTHOG
VETTHOG's Avatar
I don't think they go to the park position, they just cycle and slam against the stops. They wont go to the park position no mater where I put the wipers. Another funny thing is when the delay is on, they pause in the middle of their travel for a second then start moving again
Old 05-23-2009, 07:40 PM
TEXHAWK0
TEXHAWK0's Avatar
Taking the motor out looks straight forward, but how do you re-attach the drive linkage so that the wipers stop in the right place? I think I saw a post somewhere on how to synchronize the cam. It would be good to get that information together with this so people have the complete job.
http://forums.corvetteforum.com/c5-t...iper-arms.html
Old 05-23-2009, 09:41 PM
rustyguns
rustyguns's Avatar
i did it the old fashion way...trial and error
Old 05-23-2009, 10:32 PM
robsc501
robsc501's Avatar
Hi There:
I was wondering where do you buy the screen tray connectors?
Nice pictures & good instructions.
robsc501
To Wiper Motor Removal Procedures
Old 05-26-2009, 08:51 PM
mqqn
mqqn's Avatar
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In V Veteran
St. Jude Donor '03-'04-'05-'06-'07-'11
Originally Posted by robsc501
Hi There:
robsc501
Hi robsc501 -
You should easily be able to get those at your dealer - probably in stock and probably overpriced.
I would add to this nice write up, that there is one of the plastic pop-fasteners that is different than the other four - it is located right at the passenger side hump molded into the cowl cover.
Also, I was able to just soak the wiper arm bolts with PBlaster and then firmly grasp each arm and wiggle it up and off - protect the paint of the fender on the drivers side for safety.
Finally, try to get your hands under the cowl and push up on the pop-fasteners while squeezing them underneath to get them up and out of the holes.
best regards -
mqqn
Old 06-23-2009, 02:08 PM
SlammedC5
SlammedC5's Avatar
Is it ok to take the udders out or are they necessary?
Old 06-24-2009, 02:14 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
As far as I know,,,there there to allow water OUT and to keep things from getting in. From my expierence,,,, things (mice) can get in even if the utters are in place. Yes, you can yank them. That doesnt mean that the holes they leave still cant get clogged. Check them every once in a while!!
Quick Reply: Wiper Motor Removal Procedures
