What to do with blocks with cracked cylinder?
I've seen some pics of an AWESOME alumimum block coffee table. The 4 corners had pistons coming out of the block and holding up the glass top. Might as well figure out how to make one of those. The engine block coffee table will fetch easily double what you would get trying to sell it as scrap or as a resleeving core. Find someone with some stock OEM pistons and conrods that will part with them for little or no money...I'm sure there are plenty of guys on the forum.
I knew I shouldn't have thrown those old Diamond forged pistons out.
http://www.neatorama.com/2006/03/02/...-coffee-table/
I'd guess that the cylinder sleeves have a "rough" OD to help molten aluminum flow around the sleeve & lock-it into the block. Not the slip-fit dry liners like you would find in some other blocks. Therefore it is just scrap. It would be useless to bore out the old liner, there wouldn't be enough material to support the thin wall sleeves unless you wanted to spend big bucks to make a "wet sleeve" block.
It's $2295 to bore and sleeve to about 4.125". How much is bored out can be seen in these pics:
The thing to consider is the L92 block (the 6.2L version of the LS2) has a 4.065" bore and is about $1,300 new. With a stock 3.622" crank, a 4.065" bore is a 376cid, and 4.125" is 387cid. So if a used LS6 is about $400 plus about $2,300 to sleeve the extra 11cid is $1,400.
So looks like it'll be a coffee table.
Resident moron
Resident moron
Wow that's really nice. The light idea is great - maybe a red light where the cam goes and one down by the crank to light up the cylinders. That would be wicked.
How much does the bare block like that weight? ~85lbs I assume?
I would love to make a table someday, just need a place to put it
Dope
Dope
