Flip-up lights wont flip
`98 MN6 25K miles.
Lights will turn on but won`t flip up all the time.
If i try 2-3 times it will happen.
I noticed that with engine off they will turn on and flip up all the time.
Any ideeas ?
Any ideeas ?
same problem here but mine will flip up and not go down all the time. And when theydo go down one of the motors keeps going without stopping. Im waiting to hear what ppl got to say about this one.
I had the same problem about 6 months ago - headlights would light, but would not open. The problem was intermittent. Turns out that when I was cleaning the G-102 ground pack (see HERE), I inadvertently loosened the pin that grounded the headlight door control module. After disassembly and bending the pins back so that they would fit tightly, I have not had any issues. Maybe the connection is corroded or loose? If not, I've read that another cause could be the HDCM.
