Is there a difference between 98 Camaro LS1 heads and 02 Corvette LS1 heads?
Old 10-27-2001, 02:56 PM
AgaveCorvette
AgaveCorvette's Avatar
Default Is there a difference between 98 Camaro LS1 heads and 02 Corvette LS1 heads?
Is there a difference between stock 98 Fbody ls1 heads and stock 02 Vette ls1 heads?
Old 10-27-2001, 11:17 PM
AgaveCorvette
Default Re: Is there a difference between 98 Camaro LS1 heads and 02 Corvette LS1 heads? (AgaveCorvette)
BTTT. Anyone?
Old 10-28-2001, 01:04 AM
95autoLT1
95autoLT1's Avatar
I am not positive but I think the intake ports are different.
Old 10-28-2001, 02:32 AM
ScreaminDemon
ScreaminDemon's Avatar
Default Re: Is there a difference between 98 Camaro LS1 heads and 02 Corvette LS1 heads? (95autoLT1)
I believe both o1' and 02' LS1 vette has the LS6 intake, so intake ports on heads would be larger...
Old 10-28-2001, 08:59 AM
Mean Green
Mean Green's Avatar
CI III & IV Vote Ho
CI II, III, IV & V Vet
CI IV Bracket Champ
St. Jude Donor '03-'04
Default Re: Is there a difference between 98 Camaro LS1 heads and 02 Corvette LS1 heads? (ScreaminDemon)
:yesnod:
Old 10-28-2001, 12:22 PM
kewlbrz
kewlbrz's Avatar
Cruise-In II Veteran
Cruise-In III Veteran
i dont beleive that is the case. Unless I totally missed something, the LS6 head has a high intake ceiling within the head. Not at the port.
The only difference I am aware of is the bolt pattern for the valve cover. 97-98 are perimeter, and 99-02 are centered. The internal aspects of all LS1 heads, f-body or y-body 97-02 are the same.
To Is there a difference between 98 Camaro LS1 heads and 02 Corvette LS1 heads?
Quick Reply: Is there a difference between 98 Camaro LS1 heads and 02 Corvette LS1 heads?
