Horn Membrane Fix!!
Old 10-25-2009, 10:10 AM
  #41
old stingray
old stingray's Avatar
Good write up
Old 10-26-2009, 08:55 PM
  #42
docimastic
docimastic's Avatar
Default Forum thoughts....
Thanks, Old Stingray! (How old? I'm 60, chronologically, but will be 17 next month, emotionally! My first Vette was a '57, which I had from 1969 to 1978! Originally a 283 single 4 barrel with 3 spd tranny ... evolved to a 375 HP 327 (with Rochester FI -- thank you, Zora, you are my hero!!!) close ratio M-22 (I can't believe I can remember that!!) "rock crusher" close ratio (2:20 1st gear) with headers, traction bars, 4:56 rear end .... could pull the left front wheel shifting into second.... Sweeeet, eh?
OK, enough babbling .... Here's the dillyo .... Just want to say that I am SOOOO gratefull for the posts on this forum (and, to a lesser extent, the forums at www.z06vette.com ) ... I mean, how else would I have known how to fix a dimming climate control display? How would I have had the chutzpa (check your Yiddish!! ) to tackle replacing my my clutch, the easy if not perfect clutch master cylinder flush, seats rocking?? The list goes on, but you get the idea .....
SOOOOOO..... I try to give back to our members when I think I can add something that will be of benefit.
My philosophy: If any of us are going to survive, we all need to help each other. And here, on this forum, we DO help each other, incredibly so!!!
In speaking of my appreciation, I know I speak for many thousands of members, whether they are contributors or just "finding answers."
Sorry if this post should be somewhere else.... a "grateful members" thread or something....
Old 11-04-2009, 09:21 PM
  #43
DevilMan02
DevilMan02's Avatar
Originally Posted by docimastic
First, thanks for the kind words, Bill! Yes, I AM a patriot!
Put in the replacement reproduction horn membrane switch for C&S Corvettes today (see my post just above this one.) Works great, just as it should.
A few thoughts on doing the replacement....
First... re: accessing the 2 T-30 screws from the back of the steering wheel. (I used a T-30 bit in a 1/4 inch drive socket with a 3" extension and a ratchet. Yes, there IS enough room for the bit to drop into the wheel, so secure it, i.e, use a piece of paper towel over the bit as you push it into the socket. hahaha Happened to me and had to go buy another bit. And yes, I DID retrieve the "dropped" one!) Despite what the factory shop manual says, turn the wheel 90 degrees and access one at a time from the top, i.e. from in front of the instrument panel. Otherwise the screw can't be accessed straight enough. Downside of this is that you need to re-connect the battery to unlock the wheel (with the ignition on, obviously) to turn it 180 degrees after doing one of the screws, and then wait another 30 minutes. (Yes, I AM parnoid about working on an airbag, even though I pulled the #16 (airbag) fuse.....)
Disconnecting the airbag: After you remove the screws and pull the airbag from the wheel, pull the the PCA (position connector assurance - a/k/a the locking thingy) straight up, then the yellow plastic connector can be pulled straight out from the metal thingy part of the airbag. No turning it!) When re-assembling, make sure the connector is ALL the way in before inserting the PCA.
Last.... The biggest pain in the **** about doing this is trying to get the rubber "nibs" up through the nylon plates. Oy! I used a 90 degree pick (do YOu have a set of picks... man... I use them ALL the time..... check out Harbor Freight) to pull them up, BUT .... if i had it to do over again, I think I would pull them up with needlenose, cut them off, and then use silicone on them after the plates were in position, to secure the plates. The airbag DOES (pretty much ??) hold everything in place, but ....
Hope this helps!
80,000 miles on my Z06 - and going STRONG!!! (Can you say "powershift??!!! - I can! )
You're the man! thank you so much! I posted this link to other people with the same problem and they reported back that you had provided a place to get the part and how to do it. AWESOME. Thanks again!
Old 11-30-2009, 04:16 PM
  #44
SJPD
SJPD's Avatar
Not to take anything away from Nastymant's awesome post on fixing the horn membrane switch... Here is exciting news ... C&S Corvettes 5317 Ashton Ct, Sarasota, FL (941) 923-5064 corvettepartscenter@comcast.net has just received their first aftermarket repro C5 horn membrane switches, complete with electrical connectors. Replace using same basic procedure as Nastymant outlined at the beginning of this thread (re cutting the "nibs" etc.) Replacement switches are 59.95 (plus S&H, I assume.) I have done business (locally) with these guys (Lyle and Steve) for years, and highly recommend them. Just bought my switch yesterday, so I haven't installed yet, but Steve told me that they pulled about 20 and tested them, and all tested good. They will be wholesaling to Mid-America and likely others. (And no, I have no business relationship with them. Just trying to "help the hornless.") Beep Beep!
10 bucks for shipping to San Jose
Old 12-05-2009, 03:19 AM
  #45
Neato
Neato's Avatar
I used a hot glue gun instead of super glue
Great write up !
Originally Posted by nastymant
Well, i got tired of not having a horn here in houston..there's plenty of A-holes that needed honking at for doing stupid stuff...
so i figured what the hell! i'll try and fix it since i'm on downtime (middle of head/cam/headers install in a '98)
for starters i knew that the RH side membrane was bad, wasnt sure about the left.
So, if you decide to try this..try it at your own risk!!! Airbag deployment velocity is probably >300 ft/sec!!!
i didn't get pictures of actually removing from the steering wheel, but it's pretty staight forward when you get it loose from the wheel.
1. there are 2 torx T-30 screws that are on fairly tight from the back of the steering wheel. be patient, it takes some time to get them out!.
2. The horn positive lead is held in the steering wheel by a plastic twist lock. just push & turn about a 1/4 turn to remove. unbolt the negative lead from the grounding eye.
3. I didn't bother with the SIR disassembly instructions in the service manuals where they tell you disconnect fuses & connectors & blah blah since i've had my battery disconnected for some time now. The airbag plug just pulls straight away after unplugging the plastic lock retainer.
4.Now that we have the horn/airbag module out, here's what we do next. remove the 4 nuts on back.
5. Remove the metal retainer.
6. Now carefully pry the rubber apart on all 4 sides while lifting the airbag assembly out.
7. Now get a razor blade and with just a little pressure cut through the center of the molded rubber holding the nylon plates on. Don't cut the outboard ones like i did in this picture!!! All you need to cut are the 6 in the inner 2 columns!!
8. you should be able to separate the molded rubber and pull the nylon plates though the slit you previously made. (from the center & not the outside like i have shown!)
9. Ok with the horn membranes out, i checked both sides..Sure enough it was the rh side. Notice it's not an open circuit after removing finger.
10. I forgot to get a picture of the next step, but there's nothing to it...I separated the plastic from the bad membrane side and put 2 layers of electrical tape on the whole copper conducter for that side. effectively isolating it. this was easier than cutting & soldering. now the piece taped back together.
11. Its a pain in the *** to get the nylon plates back into the cover, but it's not impossible..just use a nice big bladed flathead screwdriver to push it into the cut rubber where it used to be..
check it after putting back into cover & super glueing the rubber
together.
Success!!! (for now until this one fails also!!)
12. Reward yourself (if you already haven't been doing that) before assembling the reverse steps...Just make sure the glue is completely dry before putting the airbag assy back into the horn cover!!!!
Old 01-06-2010, 11:39 PM
  #46
madmatt9471
Support Corvetteforum!
madmatt9471's Avatar
Location: Palmdale, Ca----- 2009 Cyber Gray 4LT A6 F55 452 RWHP 422 RWTQ- RIP 1998 C5 734 RWHP & 585 RWTQ-----
Awesome stuff - Tagged and Bagged
Thanks,Matt
Old 01-11-2010, 06:00 PM
  #47
lytspeed1
lytspeed1's Avatar
yikes my horn went off at 3 am this morning with it 23 outside!!!! I hope this fixes my problem..till then..no horn!
Old 01-15-2010, 04:17 PM
  #48
jswfl09
jswfl09's Avatar
Mine just went off today. Pulled Fuse #11 for now - I'll just add this to my to-do list.
Thanks to everyone for putting this thread together.
Old 01-15-2010, 04:21 PM
  #49
ajg1915
ajg1915's Avatar
St. Jude Donor '08
Ecklers sells them now
http://www.ecklers.com/product.asp?p...dept%5Fid=1717
A whole lot better than buying an airbag.
Old 01-16-2010, 03:51 PM
  #50
rbrtclk
rbrtclk's Avatar
I skimmed through the threads and saw no one commented on the way you placed the airbag after removal. That thing is dangerous, it should not be placed on a table face down! Should it activate inside your house, it will be a projectile! Place it with the warning label facing down, and leave it out in your garage, till time to put it back in. Just my .02 cents
Old 04-07-2010, 01:38 PM
  #51
bigleman
bigleman's Avatar
I picked mine up from Corvette Central for $59.99 + $4.99 S/H
http://www.parts123.com/parts123/yb....Z5Z5Z50000050D
Old 04-28-2010, 05:32 PM
  #52
CharlieC5
1st Gear
CharlieC5's Avatar
Default Installed a new horn membrane and the horn works!
I followed some of the steps in nastymant's thread to replace the horn membrane (which I got from Corvette Central - corvettecentral.com - item# 565100 for $59.95+shipping) and the horn works great!
Before doing any work around the airbag, I disconnected the negative battery cable, and pulled the #16 fuse located in the IP fuse panel in the passenger footwell. I let the car sit overnight with no power.
The sensing and diagnostic module (a.k.a. SDM) that triggers the airbag to deploy can supply power up to 10 seconds after the battery is disconnected. I've read 30 minutes is the least amount of time to wait before touching anything near or connected to the airbag.
To remove the bolts that hold the inflatable restraint steering module (a.k.a airbag assembly) to the steering wheel, I used a Torx T-30 power bit that's 3.5" (90mm) long and 1/4" bit size. I got it from WihaTools - wihatools.com - part # 74581.
You insert this bit into a 1/4" socket (1/4" bolt size), and use on a 1/4" ratchet that's no longer than 5.25" in length. Smaller length bits could fall inside, and you'd have to get another T-30 bit. The longer length of this bit prevents that problem.
I used a 10mm socket to remove the 4 nuts that clamp the airbag retainer down on top of the airbag. When storing the airbag while doing this membrane repair, DO NOT let the airbag sit with the metal ring facing up. The metal ring should be facing down and away from your work area and any source of heat, fire, or static electricity.
Before inserting the red horn power wire into the twist-and-turn fitting in the steering wheel housing, blow out any debris there may be inside the connector hole, and apply some dielectric grease to the end of the connector on the red horn wire.
After you've replaced the horn contact membrane and the airbag is reinstalled in the airbag assembly, checked to see that it works when you press the horn pad area. Do this BEFORE you reinstall the airbag assembly in the car. Connect a voltmeter (set for continuity) red (+) probe to the red horn wire and black (-) to the black ground wire. If everything works, the voltmeter will tell you.
Before you put the airbag assembly back in the car, take a T-30 bit and tighten the Torx bolts (you previously removed at the beginning) down to 54 lb/in. in the remaining holes on the left and right of the airbag assembly.
Connect the yellow, black, and red wires, then pop the airbag assembly onto the steering wheel. It will snap back in.
Pop the #16 fuse back in, reconnect the negative battery cable, turn the ignition to ON and make sure the airbag light doesn't stay on for too long.
I hope this helps!
Old 07-16-2010, 09:55 PM
  #53
Kev'sC5
7th Gear
Kev'sC5's Avatar
Great instructions --- worked like a charm. I had to replace the membrane to get the horn to stop blowing. Ecklers $70
Old 07-26-2010, 09:15 AM
  #54
cdkcorvette7
cdkcorvette7's Avatar
Thanks for the post! I just replaced my damaged membrane with a new one from ecklers and the horn works perfectly.
The only problem is my airbag light now flashes a few times on start-up then stays lit... Anyone have any suggestions?
Old 07-26-2010, 11:09 AM
  #55
cdkcorvette7
Originally Posted by 8VETTE7
Pull the codes and post them:
http://www.c5forum.com/ayc/dtcdic.php
Only code is 58 - SDM B0022 H C ...
Old 07-26-2010, 11:27 AM
  #56
cdkcorvette7
That is the cause of the light staying on.
Here is a link that may help diagnose the cause:
http://forums.corvetteforum.com/c5-s...rbag-code.html
then scroll to post #3.
Thanks, I actually have a separate thread going for this as I didn't want to hijack this one: http://forums.corvetteforum.com/c5-t...post1574814362
and someone just posted that info. I'm only half way through reading, but I'm guessing something didn't get put back on tight enough... I guess I'll be pulling it apart again later to check the wiring...
Old 07-26-2010, 08:34 PM
  #57
Kev'sC5
7th Gear
Kev'sC5's Avatar
If the light stays on the air bag isn't working. Make sure that the Air bag connector is properly seated and locked. I had the same problem.
To Horn Membrane Fix!!
Old 07-27-2010, 01:24 AM
  #58
cdkcorvette7
Thanks. I didn't get to it tonight, but I'm planning on pulling it apart again tomoorow to check the connection. I'm assuming you mean the big yellow connector that plugs into the center of the steering wheel behind the airbag right?
Old 07-27-2010, 07:51 AM
  #59
Kev'sC5
7th Gear
Kev'sC5's Avatar
Yes - My first try the yellow plug wasn't seated correctly
Old 07-28-2010, 09:23 AM
  #60
cdkcorvette7
I pulled the steering wheel apart again last night and it turns out that the yellow connector that runs from the airbag to the center of the steering wheel wasn't seated properly. I fixed it and... no more airbag light
Thanks again for the responses guys.
Quick Reply: Horn Membrane Fix!!
