need to adjust door so it closes tighter for wind noise how do you adjust? THANKS
If it's the door you need to adjust closer, then loosen the striker and make only small, tiny adjustments at a time until you get it tightly against the seals.
If it's window tip that needs adjustment, then do a search and you'll get good detail info on how to adjust
