A/C not blowing very much air out vents
My 97' C5 is having A/C problems,,(See other post about high outside temps). No matter what setting the A/C is on, it blows out of all vents (upper defroster and dash vents). Very little air is coming out of the vents even though the fan is blowing it's little heart out...Air coming out of vents is very cold, probably in the 40+ degree range, but there is just very little of it coming out. Wasnt a problem before these 100 degree days here in atlanta.. any help will be greatly appreciated,,,,,,,,thanks ron
PS: no DTC codes are showing,just checked to make sure..
It is almost definitely your ac vacuum hose. It's either eaten by acid down under your battery, or unplugged or cracked somewhere between the manifold and where it plugs into the actuator. Start at the back of your manifold (PITA to get to) and go from there.
Received 2,180 Likes
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Your HVAC unit damper doors are vacuum operated. Your missing vacuum. It starts at the back of the manifold and goes down to a black plactic resivour in the passengers fender area under the battery. Then it goes through the fire wall into the passengers foot well.
The lines are nylon and run inside the wiring harnesses They can crack, get eaten my rodents and or get disloved by ACID leaking from the battery.
lOOK FOR DEFECTIVE/BROKE/DISLOVED vacuum lines.
BC
BC
