AC blower problem????
Old 08-29-2007, 09:09 PM
01vetteC5
01vetteC5's Avatar
Default AC blower problem????
ok i have a small problem with my ac blower --- it dosnt work on 1 or 2 but it blows just fine on 3 and up??? any idea whats causeing this to happen?
Old 08-29-2007, 10:08 PM
speedsk899
speedsk899's Avatar
Well I am not sure what year your car is, But my 99 has the same problem except it is 1-4 that doesn't work and 5 does. On mine there are two control modules, one for 1-4, and one for 5. The one that controls 1-4 went out. I just haven't gotten around to fixing it yet. Hope this helps
Old 08-29-2007, 10:12 PM
ajg1915
Support Corvetteforum!
ajg1915's Avatar
St. Jude Donor '08
If you have manual system (option C60) more than likely it's the resistor that is in the duct housing on the passenger side.
Haven't fooled around with the climate control system.
Old 08-29-2007, 11:43 PM
0Doug@MorosoPerformance
Former Vendor
Doug@MorosoPerformance's Avatar
If your system is manual it most likely is the resistor, which is located next to the blower. It is not hard to change just a pita to get to. It is about $30 from a forum vendor.
Old 09-11-2007, 11:43 PM
rio124
5th Gear
rio124's Avatar
I am having the same problem with the HVAC blower only working on 5. Talked to the dealer and there is a TSB on this. Unfortunately it just walks through steps to troubleshoot the problem. He walked through a couple of the steps. I think they were:
Step 1: Replace blower (motor only I think.)
Step 2: Replace control board (for the blower - no idea where it is)
Didn't make it past that. Hope it helps.
-Greg
Old 09-12-2007, 12:04 AM
ajg1915
ajg1915's Avatar
St. Jude Donor '08
-Greg
The controller is right behind the blower motor if you have a manual system.
Old 09-12-2007, 12:15 AM
LoneStarFRC
LoneStarFRC's Avatar
Location: Dear Karma, I have a list of people you missed.
C60: GM part #15304891 Blower motor resistor
CJ2: GM part #52479971 Blower motor control module
HTH
Old 09-12-2007, 09:52 AM
rio124
5th Gear
rio124's Avatar
I just got confirmation that it was the resistor that caused this issue. They also found some debris in the blower (probably leaves from previous owner.) This may have caused the problem.
To AC blower problem????
Quick Reply: AC blower problem????
