Removing wiper arms C5 ?
I'm trying to replace the lower windshield weatherstrip and after removing the plastic cap and the nut from the wiper arm, the sucka won't budge ? Is there something i'm missing ?
thanks in advance
thanks in advance
I would buy a small puller before I would start putting too much force on the wiper arm posts. It could bend something or break the drive mechanism.
There is even a special puller made just for wiper blades. It is one piece with two feet that slip under the arm, and a screw with a **** on top to push the shaft out.
Like this.
http://www.toolsource.com/stinger-wi...r-p-97498.html
Any type of small puller will work if you can fit it under the arm.
Like this.
