What did I do to my motor? :(
Old 11-01-2007, 07:22 PM
  #41
VetterGetIt
VetterGetIt's Avatar
Hey Joe, never boosted my vette, but when I had my VR4, sometimes the y-pipe would blow off under hard boost, making a loud POP and then the car would die. check all the airway connections and make sure you haven't blown off a clamp or something like that.
Old 11-01-2007, 07:52 PM
  #42
chriswtx
chriswtx's Avatar
Even if the hose came loose, it should start and run with it loose...Got to be something else...Even a cracked intake should at least attempt to turn over and fire...
Old 11-01-2007, 07:59 PM
  #43
vetterlatethannever
vetterlatethannever's Avatar
Looks like its the timing chain. We popped off the oil cap and I think you can see a rocker and a spring and there is no movement when the motor is cranked. Also my dad (old school mechanic LOL) says the backfire which is coming through the manifold is a result of timing, or lack thereof.
Suprised there are no other codes popping up. And I haven't ruled out the manifold, have a bud coming tomorrow to help me pull it.
Old 11-01-2007, 08:30 PM
  #44
Wicked Weasel
Wicked Weasel's Avatar
St. Jude Donor '05-'08
At WGI my timing chain blew. All I heard was pop and then there was nothing. I tried to start the car a few times with no luck but it seemed like it wanted to start except for the occasional backfire. Only code I got was cam sensor out of position. There was no other obvious damage like oil leaking.
sucks big time. I had a 402 already built knowing my racing engine would eventually die. I thought it would be a rod or something else but chit happens (and i had a double roller).
Old 11-01-2007, 11:04 PM
  #45
peter pan
Life Time NCM #2196
Support Corvetteforum!
peter pan's Avatar
Received 1,096 Likes on 808 Posts
Joe, That sucks big time, and I would put this over in FI section lots of wrenchers there, like I know Chris is one of those
Old 11-02-2007, 08:02 AM
  #46
mojo1
mojo1's Avatar
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13-'14-'15, '19
Sorry to hear Joe, good luck on the fix ....
Old 11-02-2007, 03:37 PM
  #47
waupachino
waupachino's Avatar
That sucks, but it was my first guess. A lot of times a catastrophic mechanical failure will not set a code because there are not sensors tied to the part that failed. For example, Timing Chain, Rod, Crankshaft, Block cracking, Etc... Good luck with the repairs and hopefully it didn't wipe out all the valves and scar the Piston tops.
Old 11-02-2007, 04:41 PM
  #48
JR_VETTE
JR_VETTE's Avatar
Mid-TN Events Coordinator
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16
Why don't you just pop a plug out, and check the compression. That will rule out just about everything 'mechanical'. Pulling the engine at this point is a little pre-mature in my opinion.
As Bill Curlee stated, start with the basics...Spark, fuel and compression. All of these can be easily accomplished with minimal tools and time.
At least that's my thoughts.
Old 11-02-2007, 05:59 PM
  #49
fsuforever
fsuforever's Avatar
Old 11-02-2007, 07:30 PM
  #50
vetterlatethannever
We have spark and fuel (at least in the rail), still need to check compression, the T/B is working as well. Dang I was ready to take her out this weekend too
Old 11-02-2007, 07:44 PM
  #51
Greg_E
Greg_E's Avatar
Well if indeed it is a broken timing chain, that is a pretty poor excuse for a diagnostic system. You can turn the crank over several times, the PCM never sees a signal from the cam sensor but never sets a code!!! You learn something new every day. Time for me to pull out the manual and do my homework.
Old 11-02-2007, 07:46 PM
  #52
vetterlatethannever
That has me confused as well. Guess we'll find out soon enough.
Old 11-02-2007, 09:08 PM
  #53
AMRAAM
AMRAAM's Avatar
i haven't been on much lately and just saw this thread. Sorry to hear this, Hope i don't run into the same issues when I finally get mine on. I didn't read the entire thread, so forgive me if the problem has been found. Any chance a part of the intake piping blew off? My turbo 3000gt used to do that frequently when the boost was turned up. The piping was fine for stock pressure, but when turned up a bit, It would blow the y pipe off the throttle body.
Good luck, doesn't sound too serious.
Old 11-02-2007, 10:05 PM
  #54
AMRAAM
AMRAAM's Avatar
oops, guess I was a bit late.
Old 11-02-2007, 10:39 PM
  #55
PFMC3
PFMC3's Avatar
If timing chain broke the noise would be like a bunch of bolts floating around in the motor because valves would be hitting pistons.
Been the done that
Old 11-03-2007, 12:33 AM
  #56
vetterlatethannever
No prob man, any and all advice (even repeat ) is still appreciated How long before yours goes on?
Old 11-03-2007, 12:45 AM
  #57
vetterlatethannever
Originally Posted by ArKay99
Lost timing chain, kissed a few pistons with the valves too... I hope not... Best of luck.
Any chance of not having other damage (pistons, valves) with a small cam and stock (unmilled, maybe more clearance) heads? Or should I expect the worst? Already planning for it.........
To What did I do to my motor? :(
Old 11-03-2007, 07:54 AM
  #58
PFMC3
PFMC3's Avatar
I'm honestly still in my original theory.
I Do no think it popped the chain. Easy way to find out pull a valve cover turn the motor over. I think you are going to find something a little less severe.
Old 11-03-2007, 09:20 AM
  #59
vetterlatethannever
I'm gonna pick up some tools later this morning and check under the valve covers just to be 100% sure. And boy I hope you are right.
Old 11-03-2007, 10:14 AM
  #60
stormrider
stormrider's Avatar
Man, I don't have the words to express how bad I feel for you. I hope you find the problem quickly and and fix is easy and cheap. Hang in there, I went through my own phantom problems last Fall; I know how frustrating it is.
Quick Reply: What did I do to my motor? :(
