Fuel level sensor and sender
Is it possible to replace the fuel level sensor or sender in the right tank without removing the tank? The car is 2004 Z06. The tank system is different on 2003-2004 than earlier models.
Have you tried Techron if your sensor is acting up? Usually fixes it. Use only top tier gas, see toptiergas.com
The sulphur in gas affects the fuel level sensor.
Good luck.
Good luck.
No, on any C5 the fuel tank must be removed to replace the sensor, as it comes out of the top of the tank. As suggested above, try Techron and see if that helps clear the problem.
Nope
The PICS are from someone installing another type of fuel pump.
Was posted about a month ago. BIGHANK
unfortunately no
This post has good picks of the "FFS" fuel system, scroll to post 12
http://forums.corvetteforum.com/show....php?t=1746325
This link explains it all
http://www.corvetteactioncenter.com/...el+Tank+System
Referring to Bighank's post here is a link
http://www.cajundude.com/racetronix.htm
Fuel level sender and sensor
Thanks for information.I have already tried strong addective from GM for this problem.Nothing works.One guy working with Corvettes told me that i need new softwear to the computor for this problem.Somthing GM told him.He is going to put new softwear in my car on Monday.I have never heard about this before.
http://www.corvetteactioncenter.com/...ram+the+PCM%29
Here is some more info on sender problems on the "FFS"
http://www.corvetteactioncenter.com/...sage+Displayed
You never did say what is actually happening with cars fuel gauge.
My probelm is this
There is a bulletin about recalibrating the PCM for fuel gauge,
it drops to empty after some minutes and check gages light comes on together with low fuel on the dic. But after I step at the brake pedal the pointer at the gage goes up to half tank for some minutes and go back to empty again. Even when i stand still and push the brake pedal down the pointer goes up to half tank. See my masage earlier.
