Air fuel ratio
Air fuel ratio
What would be a safe A/F ratio? I am having my car tuned after the header install and the temperature will be around 40 degrees F.
Yeah, Joe is right; if your tuner doesn't know, get another tuner.
That being said, 13/1 is about as lean as I've seen anyone here go on a midly modified car, most like to go about 12.5.
DG
DG
If you every run N2O, you might want to go a little richer just for a little added saftey.
You might want to drive the car a little to let the PCM adjust (learn) to the headers. There are some tuners that simply adjust the PE to get the proper WOT #s, which is not necessarly a terrible thing, but once the PCM finishes adjusting for the new mod, (usually enriching the A/F) it causes the WOT #s to be off again.
