What is the correct fluid for the power steering?
01-19-2008, 12:12 AM
I am going through all of the fluids in my 2002 C5 Coupe with manual transmission. What is a good replacement for the power steering fluid? Some people say synthetic ATF, others say only GM PS fluid. What is the correct replacement?
01-19-2008, 12:14 PM
01-19-2008, 01:07 PM
I'd just go to the dealer and buy some GM PS fluid. It's not very expensive, and then you don't have to worry about what's ok and what's not ok.
01-19-2008, 03:59 PM
what I use
01-19-2008, 05:08 PM
CI 4-5-6-7-8-9-10 Veteran
St. Jude Donor '07-'09
I use Red LIne
01-19-2008, 09:00 PM
Quote:
Originally Posted by
90Z51
Does anyone have the part number of the correct GM fluid?
01-20-2008, 12:10 AM
Vette Ed
I use Red LIne
I will use that beginning in april when I start getting it for free
Everything I use will be Redline in April.
01-20-2008, 12:14 AM
John Galt
Hi, this is what I have in my notes for my FRC...Valvoline Synpower-Power Steering Fluid meets the GM specs listed in my manual. GM part number on the bottle (GM 1050017). Gee
01-20-2008, 03:41 AM
John Galt
All the fluids are in the Owners manual Page 7-19
GM Power Steering Fluid (GM Part No. 1052884 - 1 pint, 1050017 - 1 quart, or equivalent).
01-20-2008, 11:09 AM
Thanks! I will go with the Valvoline Synpower.
01-21-2008, 10:39 AM
John Galt
Yep, that's what I use also.
01-25-2008, 11:55 AM
I kept it simple and used all GM fluids.
01-27-2008, 01:50 AM
DeeGee
Redline also has a product that is equivalent to the GM part for our C5 power steering fluid:
http://www.redlineoil.com/pdf/8.pdf
01-27-2008, 02:07 AM
John Galt
What is its cost compared to GM's fluid?
01-27-2008, 08:59 PM
oops
ok ... you guys got me nervous... I have ATF in mine been changing it with every oil change the past year... no issues yet...
01-27-2008, 09:49 PM
RaleighSS
02-09-2008, 07:33 PM
RaleighSS
i think atf is actually better especially to fix leaks
which atf do you use?
1050017 ,
1052884 ,
2002 ,
c5 ,
corvette ,
equivalent ,
fluid ,
fluids ,
gm ,
number ,
part ,
power ,
products ,
replace ,
steering
