2000 recall question
I have a 2000 FRC and was wondering if there was somewhere online where I could type my VIN to see if the car has had the recall performed?
there were 2 recall's for the 2000 seatbelt's and column lock
http://www-odi.nhtsa.dot.gov/recalls/recallsearch.cfm
I believe, if you go here (Select GM Owner Center lower on the page) and register, that with your VIN you can see the service history.
http://www.goodwrench.com/Services/index.jsp
If the column lock has been fixed you should be able to turn the wheel with the car off. Right? Heard it here but can I get a confirmation. If so you can find out by going to your garage and ckecking.
