Code P0449 /vent valve solenoid
7th Gear
Has anyone had a problem with the vent valve solenoid ??
I have a code PCM (P0449)that I've cleared a few times but it keeps coming up. Any input would be appreciated.
More then likely the solinode is bad, but do check the connection and vacuum supply.
If it's your valve I think there less than $50 from the dealer. It throws the code after the second failure.
If you want to look at diagnostics on the issue yourself and maybe replace it also I can provide the FSM information. Just not home now.
You would need to tell us your year car in case there are any slight changes between the years. I know mid year 2003 and later might be different for sure since the whole system is different.
I replaced solenoid/valve
I just replaced the "vent solenoid" on my 2008. Got it from the dealer, and also had to get a short adapter cable because the new solenoid has a slightly different plug size. The old solenoid was "open" - no continuity, so it didn't operate. It was a "fiddly" job because on my back under the car, I didn't have the leverage and access that a lift would provide. The solenoid is mounted on a bracket mounted on the frame. I got at it from the passenger side of the car, and didn't need to remove the wheel. I cleared the code by disconnecting the battery and then re-indexed the power windows.
